18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Titleblocks
11 Posts No Rating |
The company I work for has 7 different offices, thus we have 7 different addresses. I'd like to create one titleblock family with 7 different components each with a different address. So, when I load the titleblock family I can pick from the type selecter the proper titleblock for the office I want. Similar to how a dynamic block works in ACAD. Is there a way to do this or do I have to create a seperate titleblock family for each office? Thanks, Matt
You can make use of a 'type catelog' in Revit that holds all the office and address information. When the user loads the titleblock family they are presented with a type selection grid. Load a steel column to see a type catalog in action. You need to create generic annotations that you load into your titleblock and then link to the parameters fed from the type catalog. It gets a bit tricky and is not something most newbies can get a handle on. Check the Revit help file for some guidance on type catalogs. You could also use simple visability parameters to control the text display of each office and make a new 'type' based on the visibility selections. HTH get you going
Thanks for the suggestion. I think a visability setting is exactly what I want. How would I go about creating one or actually 7 of those in one titleblock?
Take a look at this example for some ideas on how to accomplish with visibility parameters.
I see now. Thank you Tom. That's a big help.
TitleBlocks |
Fri, Dec 8, 2006 at 8:08:02 AM
Titleblocks & Design Options |
Mon, Dec 8, 2008 at 2:06:33 PM
Labels in Titleblocks? |
Mon, Nov 10, 2008 at 3:30:01 PM
Titleblocks |
Mon, Mar 17, 2008 at 3:03:10 PM
Multiline text on Titleblocks |
Sun, Oct 5, 2008 at 8:17:13 PM
