Forums >> Revit Building >> Technical Support >> help me for curtain wall
Mon, Dec 11, 2006 at 1:01:03 PM | help me for curtain wall
voyager99
voyager99 Avatar
Hi, i am trying to create a 10 floor facade w/ curtain wall. I changed the mullions for 1st floor. How can i repeat the same thing for the other floor. Or is there any other way? Help me please. Thanks
Mon, Dec 11, 2006 at 5:58:56 PM | help me for curtain wall
eldados
eldados Avatar
4.5 Stars: 8 Votes
so I take it that the rest of the curtain walls on the the other floors are in place?
box select all your first floor, use the filter and uncheck all but "walls (curtain wall grids)" and "curtain wall mullions"
copy and paste using select levels by name, select all your levels...
Integrator
KarelCAD
Tue, Dec 12, 2006 at 7:27:41 AM | eldados
voyager99
voyager99 Avatar
Thanks
I tried the same thing. but instead of selected levels, I made a group and copied this group to all repeated modules. But yours seems better way to do it. And is there a way that I can create my own pattern curtain wall and just extended thru the floors?
Curtain Wall Panel to Curtain Wall Door
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:44 PM
Splitting a curtain wall to change the type of wall it is
Thu, Aug 6, 2009 at 12:46:42 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
curtain wall
Sat, Jan 10, 2009 at 10:01:35 AM
Page generation time: 0.5481
