Forums >> Revit Building >> Technical Support >> Area Tag issues
Sun, Dec 10, 2006 at 10:52:42 PM | Area Tag issues
MarieCz
Hey guys, we just got 9.1 at work and there seems to be something wrong with my Area tags...
Story is: did area plans for my both of floor plans using 'rentable' and made a schedule. Good. The plan changed and the Garage moved to the upper level, so i drew the boundary and tried to bring the tag in - nothing. Bad. It doesnt say that my areas not enclosed or anything, the options toolbar is still saying what to do and my mouse looks like its about to place something but still nothing. Why wont it not let me add another tag?
Also, another problem i encountered soon after: i need my roof area so i go to my area settings and create another type of area scheme - 'Roof Area'. Then used level 3 as my area plan, drew the boundary and once again - NOTHING! Ahhhh!!! lol.
So you see, im quite stumped. It doesnt make sense that you'd need different types of area tags for all your different area plans. But it really doesnt make sense that it wont let me add another tag to an area plan that already has 3 of the same type of tag in it!
I would really appreciate any info. Hopefully its just something simple and i can blame it on being blonde...
I am a-MUSE-d
Mon, Dec 11, 2006 at 9:49:29 AM | Area Tag issues
TomDorner
4.5 Stars: 25 Votes
Areas and Rooms in 9.0/9.1 changed.  Areas and Rooms are now actual objects rather than implied objects.  In order to tag a room or area the object needs to exist first .  On the Room and Area tab you need to place a room or area object.  They can be tagged upon insertion just like doors, windows etc. or you can place and tag later.
 As for creating different area schemes for each level, taht is not how it is done in Revit. An area scheme can have multiple views each based on a level.  While it is not effectively documented, the help file does have some basic information.
HTH
Tom
www.reviteer.com   http://twitter.com/Reviteer
Mon, Dec 11, 2006 at 7:20:39 PM | Area Tag issues
MarieCz
Ohh... i see - its more a 'room' bounding... Yea it works now. *sighs with relief*
I just clicked on area instead of area tag :D excellent
Hmm... wat would be an advantage of changing it to this way? wats the reason? cos ive never used 'room' tools, just area...
Thanks for ur help!
I am a-MUSE-d
Tue, Dec 12, 2006 at 9:45:15 AM | Area Tag issues
TomDorner
4.5 Stars: 25 Votes
Rooms and Areas changed to actual 3D objects to accomodate Revit Systems (MEP).  Rooms now have a top limit and hence a volume which can be exported to MEP analysis software and then have that analysis brought back into Revit.
Frankly from a pure architectural standpoint I liked it before the room and area objects showed up in 9.0.
Tom
Tag problem
Wed, Sep 13, 2006 at 3:47:54 AM
tagging the surface area of a floor (revit2009)
Wed, Mar 3, 2010 at 11:14:36 AM
Room Tag vs Area tag
Tue, Aug 18, 2009 at 1:10:59 PM
Tagging 2 rooms with the same tag/area
Wed, Nov 20, 2013 at 8:11:44 PM
Editing a room tag
Thu, Oct 12, 2017 at 3:17:41 PM
Page generation time: 4.4820
