Forums >> Revit Building >> Technical Support >> Wall Detail
Fri, Dec 8, 2006 at 12:53:43 PM | Wall Detail
Flick219
Flick219 Avatar
How do you create your own wall detail... For example a wall for a log cabin???
Fri, Dec 8, 2006 at 5:52:02 PM | Wall Detail
normanoid
If you want to create your own detail from scratch using drafting tools/techniques, create a "Drafting View" from the View tab and start drafting. When you want to link a reference to the drafting view you can create a Callout, Section, or Elevation and use the "Reference other view" drop down box to pick the appropriate detail.
Sun, Dec 10, 2006 at 6:02:09 AM | Wall Detail
latemore
latemore Avatar
3 Stars: 2 Votes
there have been several threads on log cabins on revit city.  just tested searching 'log', anf there's loads of suggestions - have a look.
Detail Component visibility from wall section to detail callout view.
Thu, Oct 8, 2009 at 3:54:42 PM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ]
Sun, Dec 7, 2008 at 3:51:44 PM
19
Wall assembly layers not showing in fine detail - Revit 2015
Wed, Nov 19, 2014 at 12:16:01 PM
Wall tag that includes detail reference
Fri, Jul 17, 2015 at 12:50:19 PM
wall tags in detail callout
Tue, Aug 1, 2006 at 9:42:22 PM
Page generation time: 0.6339
