10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Interior Elevation disappearing lines
Has anyone ever had the problem when printing interior elevations, certain wall and floor lines wont print. They are visible on the screen but when printed they disappear. I do not think it is a driver issue because it happens on every printer we have, including the PDF writer. Anyone else ever have this problem? Please help! Thanks Adam
25 Posts No Rating |
this is an old issue and has to do with how your crop line sits on top of your view. In our office we pull the crop lines slightly outward and draft wide lines over our elevation edges. Would be nice if the crop box could be redifined with wide lines, wish item for a long time.
I just posted the same question and I just got my answer with a little fiddling and a hint from a friend. Select the boundary box. right click and select Override Graphics In View (by category) change the line weight to a higher value. BAMM - your boundary box is now a fat line for interior elevations!! Anyone know how to make this change permanent to either all projects as a system setting or at least to Interior elevation views?
----------------------------------- Revit Architecture 2010 |
The crop boundry line over-ride is only available in Architecture - wasn't in 9.1. Our problem is that we leave all of our crop boundries on and then in mass prints, we use the checkbox to not print crop boundries. Looks like we may change that process now.
disappearing elevation "arrow" |
Fri, May 2, 2008 at 8:31:02 AM
Lines disappearing in elevation/section view. |
Thu, May 16, 2013 at 7:31:32 AM
CAD import disappears in interior elevation |
Fri, Dec 6, 2019 at 12:40:46 PM
Interior Elevation Tags |
Mon, Jul 21, 2025 at 11:28:06 AM
Revit 2011 Multiple Interior Elevation References |
Wed, Oct 26, 2011 at 9:01:48 AM
