Forums >> Revit Building >> Technical Support >> Purging Line-Types
Thu, Dec 7, 2006 at 12:32:32 PM | Purging Line-Types
gdoorn
1 Stars: 1 Votes
I have a site plan with a bunch of line-types, and a bunch of other line-types that arent in use, but still exist.  Is there a quick way to 'purge' line-types that are not being used.  i dont see it in the purge unused box, and i am hesitant to do it manually in the Line Styles dialogue box because you cant tell if it is being used from there.
 Any help/advice is appreciated.
Thank you-GD
Mon, Dec 11, 2006 at 10:55:13 PM | Purging Line-Types
eldados
eldados Avatar
4.5 Stars: 8 Votes
no, the only way at the moment is to delete it in the line type one by one...
Integrator
KarelCAD
Tue, Dec 12, 2006 at 6:41:21 AM | Purging Line-Types
The good/bad news is .... you can delete any line style.  If lines exist that are that style, they will be re-defined as "thin" lines.  Check it out youself so you feel comfortable doing it.
Changing line types and styles in cross section views, wall types etc...
Wed, Apr 12, 2006 at 12:52:32 AM
Purge Command - possible to purge family types accidentally?
Tue, Aug 20, 2013 at 12:01:08 PM
HYDRAULIC LINE TYPES EG. STORM WATER, SEWER ETC - HELP!!!
Wed, Jan 21, 2009 at 6:04:20 PM
Custom Line Types
Tue, Jun 17, 2008 at 2:03:22 AM
12
appearance of line types of existing objects in a "new construction" views
Sat, Feb 26, 2005 at 10:35:37 AM
Page generation time: 3.1401
