Forums >> Revit Building >> Technical Support >> Tagging items above
Wed, Dec 6, 2006 at 3:45:44 PM | Tagging items above
Kartyh
I have a situation where I have a metal siding above 6'-0" and brick veneer from grade to this point.  How can I tag both the brick veneer wall and the metal siding above (two different wall types) in the same view. I can only get the tag to link to the lower wall. I have tried playing with the view range and hitting tab. The only way I have been able to tag both is to adjust my cut plane up to above 6 feet but I do not want the profile of the metal panel to show just the brick veneer in plan.
Any thoughts. Thanks
Thu, Dec 7, 2006 at 2:54:35 AM | Tagging items above
eldados
eldados Avatar
4.5 Stars: 8 Votes
in order for revit to tag it, it needs to see it.
put a view region over your siding, tag it and than use the Linework tool to hide.
HTH
Integrator
KarelCAD
Thu, Dec 7, 2006 at 1:38:41 PM | Tagging items above
TomDorner
4.5 Stars: 25 Votes
To tag the higher walls I temporarily set my cut plane to expose and tag them.  When done, I reset my cut plane back to normal and the upper tag does remain.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Thu, Dec 7, 2006 at 4:30:11 PM | Tagging items above
Kartyh
I tried adjusting my cut plane up. This enabled me to tag the wall above but when I lowered my cut plane the tag went away. Is their something I am missing?
Thu, Dec 7, 2006 at 4:56:32 PM | Tagging items above
TomDorner
4.5 Stars: 25 Votes
I stand corrected.  I swear though that it used to work once upon a time since I have done it!  It is another reason to not like stacked walls.  Why can't the stacked wall have a type mark?  That way you could tag them in a plan view.
I guess the view range thing with the linework tool or simple dumb text wall tags may be the answer.
Tom
Tagging items based on view
Wed, May 9, 2012 at 3:01:54 PM
Tagging Graphical Column Schedule
Wed, Nov 24, 2010 at 8:41:14 PM
Tagging in Section
Tue, May 23, 2006 at 7:54:43 PM
Revit Structure wishlist items
Tue, Apr 14, 2009 at 4:52:47 PM
EDITING TEXT LEADER ARROWHEADS AND LINES
Thu, Aug 14, 2008 at 3:14:57 PM
Page generation time: 0.0876
