16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Door Numbering
18 Posts No Rating |
Hi all,
Ocasionally when renumbering doors, I'll get a message that says the door number is already in use. The catch is that the number that the program claims is in use is not anywhere visible in the project. Does Revit maintain door numbers as information somewhere other than directly on the tag that and could something like that cause this? Should I be concerned about how this will affect scheduling?
Thanks in Advance
To find duplicate numbering, create a temporary schedule with all doors visible sorted by numbering. You will then be able to locate the duplicates by selecting the door in the schedule and choosing to show...
A tag simply reports information kept in the door properties itself. So when you change a tag you are actually changing the door properties...
Hope this helps.
Door tag numbering / room tag numbering |
Wed, Nov 2, 2005 at 5:08:50 PM
Stair numbering |
Tue, Feb 27, 2018 at 4:34:51 PM
Revision Numbering |
Thu, Jun 18, 2015 at 2:33:41 AM
Numerical numbering for Door tags |
Mon, Feb 11, 2008 at 7:43:22 AM
How to change view title numbering from 1 to 01 |
Mon, Sep 29, 2025 at 10:02:00 AM
