Forums >> Revit Building >> Technical Support >> 3D Views-Can you hide foundations/generic models underneath the topography?
Wed, Dec 6, 2006 at 8:10:02 AM | 3D Views-Can you hide foundations/generic models underneath the topography?
mpenn
1 Stars: 1 Votes
Is there a way to hide the foundations underneath the topography?  I have a site which slopes quite a bit.  I want to put the 3D view on my cover sheet, but you can see the foundations and some generic models I have under the grade line no matter how close I move the clip box.  It just looks strange...any ideas?  Thanks in advance...
Wed, Dec 6, 2006 at 8:22:45 AM | 3D Views-Can you hide foundations/generic models underneath the topography?
framerman
4 Stars: 13 Votes
I struggled with this for awhile too. One way I found is to make your foundation a phase and turn the phase off when you need to view/print your sheet.
Wed, Dec 6, 2006 at 2:04:04 PM | 3D Views-Can you hide foundations/generic models underneath the topography?
mpenn
1 Stars: 1 Votes
I came up with a work around solution.  I built a wall just under the edge of the end of the topography so you can't see underneath the grade.  You only see the wall.  It won't show up anywhere as it isn't on my floor plans.  It works, but any other ideas would be great!
Giving topography thickness when rendering
Thu, Jan 22, 2009 at 9:42:06 AM
Generic Models
Wed, Aug 1, 2007 at 12:03:17 PM
Topography Hatching
Tue, Feb 28, 2012 at 8:15:31 AM
Generic Annotations - Hiding Labels
Wed, May 16, 2007 at 4:17:31 PM
Generic Model Materials
Wed, May 18, 2005 at 5:03:38 PM
Page generation time: 0.3793
