Forums >> General Discussion >> Wishlist >> Importing 3D components created iin other file formats?
Tue, Dec 5, 2006 at 5:40:00 PM | Importing 3D components created iin other file formats?
MNInteriors
is this possible?  TurboSquid.com has great stuff but not in .rvt.  Is there a way to get a file from .dxf in CAD and then into Revit?  Thanks very much.
Tue, Dec 5, 2006 at 5:53:58 PM | Importing 3D components created iin other file formats?
TomDorner
4.5 Stars: 25 Votes
Yes it is possible. See if this tutorial helps you out.
http://www.revitcity.com/tutorials/how_to_grow_your_family/
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, Dec 5, 2006 at 6:10:04 PM | Importing 3D components created iin other file formats?
MNInteriors
Thank you TomDorner, we'll get working on that tomorrow!
Wed, Dec 6, 2006 at 12:04:38 PM | Importing 3D components created iin other file formats?
MNInteriors
Tom - we will assume that if the file is already in dwg or dxf and we don't have Max or Viz we can jump right to the CAD step.  Also, my drafter trained on 2004 but we have 2007 inhouse.  How does he turn on layers?  It's not on him menu.  Thank you.
Wed, Dec 6, 2006 at 12:51:48 PM | Importing 3D components created iin other file formats?
framerman
4 Stars: 13 Votes
is it something like layer manager? it's been so long. or I think select the item and right click for properties
Wed, Dec 6, 2006 at 3:47:44 PM | Importing 3D components created iin other file formats?
TomDorner
4.5 Stars: 25 Votes
I have not used AutoCAD in a long time either and have never used 2007.  I still believe you can type in LA or -LA at the command prompt.
 And yes, if the file is already in DWG or DXF you can skip the Max/Viz step.
Tom
embed other file formats (e.g. pdf) in components
Wed, May 5, 2010 at 1:56:08 AM
importing Topography
Mon, Jun 5, 2006 at 8:19:07 AM
Importing a cad file
Fri, Apr 27, 2012 at 3:33:21 PM
How to print different sheet formats in PDF?
Mon, Jun 5, 2023 at 2:07:16 PM
Problems when importing Architects Revit File
Fri, Feb 6, 2009 at 12:47:49 PM
Page generation time: 1.7910
