18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Rendering Sketchup Objects In Revit - Material Loss?
9 Posts No Rating |
Hey all...I'm a bit of a newbie to this forum so I thought I'd throw out this question to see what kind of gurus we have here . Although I have a feeling that my fix is a simple one. I've been building models in revit lately and been toying with renderings...well the last project I completed needed palm trees and Revit has a pretty crappy selection of those objects to choose from. I ended up exporting out some objects from ArchiCAD as dwg files and bringing those in, but even that didnt work out so well. So, being the avid Sketchup user that I've been for years I figured I'd try out the new linking. I dont know if I did it correctly but it seemed a very simple process. I just saved out the sketchup palm tree I wanted to use with all the colors and materials set...then imported it as an autocad format file in Revit. The palm tree came in perfectly in form (although the scale was a bit skewed)...but it had no materials at all...and i was not able to edit anything in it. Same result when I tried rendering...its a perfect albino palm tree...I know there's a silly little step I'm missing in here somewhere and I was hoping someone could point it out to me - How do I export SU files and import them into Revit in such a way that they retain the material/color information? Side question...I was unable to set a phase for the SU trees once I brought them in...so as they were going in for landscaping I was unable to use them in that manner...anyone know a way around that little issue? Thanks everyone.
I think your file in AutoCAD format you need to make sure that everything is set to bylayer and bycolor. I don't know if you had done this step or not. This was one of the steps necessary when importing 3d modeling from any other program. From there I think you might be all set.
9 Posts No Rating |
Everything is set to come in 'by color'...it just comes in completely white w/o any color information whatsoever...I know other have had this issue but I don't know if there is any resolution as of yet...hopefully someone can help me.
9 Posts No Rating |
Cmon...nobody knows how to do this? I can get colors to come across from Sketchup but they will not render...has anyone found any workarounds at least?? Thx.
2 Posts No Rating |
Any answer to your question? I just started Sketchup and Revit. How do you import SU model into Revit?
From the Revit help file: SketchUp (SKP) files can be imported directly into a Revit Building mass or in-place family. TIP:Make sure you import the geometric data needed for the Revit Building capability you plan to use. For more information, see Suitability of Imported Geometry. When importing SketchUp files, keep these considerations in mind: To import SketchUp files - Create a mass or in-place family. See Using the Mass Editor or Creating an In-Place Family.
- Click File menu
Import/Link CAD Formats. - In the Import/Link dialog, navigate to the directory containing the file.
- Select the SKP file type.
- Click Open.
1 Posts No Rating |
Hi, I have had the same problem with importing CAD and Sketchup Files and rendering them. I just figured out that if you partially explode the Sketchup file and go to Setting > Object Styles > Imported Categories Tab if you expand your imported family there will be colors and materials assigned to each layer. So click on the material you want to change...and you'll notice there's a color assigned to it but not an accurender material so you have to reassign a material to it in REVIT so it will render it. I found it kind of a guess and checking game assigning the right materials to each layer because I didn't make the object so I wasn't familar with the names. Hope this helps, I was very happy I figured this out. I haven't tried it with AutoCAD blocks yet but I'm hoping it will work similarly as it did with the Sketchup ones!!
Sketchup to Revit material problem [ 1 2 ] |
Wed, Jun 30, 2010 at 11:58:37 AM
26
Sketchup model into Revit |
Tue, Jan 8, 2013 at 12:06:20 PM
please help- tried everything to get objects to accept material... |
Thu, Apr 16, 2009 at 12:45:04 AM
Sketchup to Revit - Layer/Material Problems [ 1 2 ] |
Thu, Jun 10, 2010 at 11:04:46 AM
24
Manipulating sketchup objects in Revit |
Tue, Jul 17, 2007 at 9:24:33 AM
11
