9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> non-transparent glass
1 Posts No Rating |
Hi, I was wondering how do I make non-transparent glass on acurtain wall or exterior glass wall. Also is it possible to make glassskylights?Julia
You have several choices for curtain walls. You can choose a solid panel, glass (the default), you can put in a wall type, you can put in a curtain wall door or you can define your own panel. (You can also change the default material settings for glass ... but that will change every family that has "glass" in it.) For windows, you can redefine the glass in the family to some other material. Most window type families are defined using "glass" but you can change them to ...glass 1, glass 2 or whatever then assign a material to that name. When you do that, you can have different transparancies, colors, reflectivity and rather or not the material is self luminescent. Lots of choices ... experiment.
you should be able to go to Settings>Materials>Glass(or your specific material) and adjust the transpareny here. Skylights are the same way. You would make a (roof hosted?) family and the glass would be a solid mass (an extrusion for example). Then you would give this mass your material assignment. You then insert the family into your drawing onto your roof surface.
Making glass transparent |
Sun, Apr 30, 2006 at 9:33:38 AM
Glass keeps rendering black not transparent |
Mon, Jan 23, 2006 at 4:01:41 AM
Glass in doors transparent only on one side - any ideas? |
Sat, Jun 7, 2025 at 1:32:50 PM
transparent glass in elevation |
Thu, Dec 22, 2016 at 3:43:03 AM
Transparency of glass windows in 3d views |
Wed, Aug 5, 2009 at 10:43:37 AM
