12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Model Cut Pattern?
23 Posts No Rating |
Hi,
Is it possible to use a Model pattern in the cut view? I'd like to be able to count the number of bricks up to a window when I'm looking at a section view. If I could assign a Model-mode brick pattern this would do it, but the Model option is greyed (grayed) out for cut patterns. Is there a way?
Thanks.
8 Posts No Rating |
Sorry there is no way to do this, however you can quicly and easily do what you want with a repeating detail componant.
there is even a brick detail componant in the metric library already.
just creat a new repeating detail using a brick and mortar at a fixed spacing and you can add these to your secions in no time.
I also find it useful to align and lock the detail to the model so if the wall moves the detail does also.
cut pattern issue |
Wed, Jan 28, 2015 at 3:53:15 PM
loss of cut pattern |
Fri, Nov 28, 2014 at 8:47:10 AM
Revit 2015 Solid Cut Fill Pattern |
Thu, Sep 22, 2016 at 8:27:54 AM
Rendering...weird cut pattern? |
Tue, Aug 11, 2009 at 2:30:12 AM
Stiar cut pattern or fill pattern. |
Sun, Feb 19, 2006 at 11:46:36 PM
