24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Filtering a phase that you have created
208 Posts No Rating |
Hi all, Can you filter a project phase that you have created? eg. If I created a phase called 'roof' and assigned this phase to my roof elements, can I then create a filter that only shows 'New + Roof' and consequently have the roof dissappear if the filter is set to just 'New' cadjockey
Hi all, Any ideas as to how to work around this challenge? cadjockey
Of course you can, simply create new phase filters in your settings for each of the situations. Does the Roof phase occur before or after "New" Phase? So you'd create one phase filter that shows New + Roof (You can set graphic overrides if you need it), then another that sets Roof to not display. However, if its a future phase it won't show anyway... HTH.
Regards,
Chris.
Hi Mr Spot, I think I have the 'past to future' sequence messed up. How do I rearrange the sequence? Can phase filters be deleted and not merged? cadjockey
As you can't move phases about in history due to their links with previous and future phases for demolition etc, you would need to create another phase in the appropriate time, then setup a phase filter to only show the elements that exist in the incorrect phase. Setup a 3D view using this setting then select all the geometry and change to the correct phase. Then you can use the combine option to get rid of the incorrectly position phase. HTH.
Regards,
Chris.
Worksets - Phasing - Phase Filtering Training Videos Now Available |
Thu, Feb 23, 2006 at 8:32:50 PM
Phase filtering |
Wed, Nov 22, 2006 at 9:19:32 PM
Worksets - Phasing - Phase Filtering Video Tutorials Now Available |
Sun, Jul 17, 2005 at 7:52:59 PM
Maintaining "Phase Demolished" properties. |
Thu, Jun 18, 2015 at 8:19:39 AM
Schedules - filtering by view or duplicate? |
Mon, Jul 28, 2014 at 8:24:36 AM
