Forums >> Revit Building >> Technical Support >> Generic Annotations - Hiding Labels
Fri, Dec 1, 2006 at 1:00:25 PM | Generic Annotations - Hiding Labels
benfischer
I need to be able to hide the label in a generic annotation along with the linework WITHOUT hiding all my other generic annotations. I can do this with the line work by creating a subcatagory but there does not seem to be a way to hide the label without hiding all the generic annotation catagories. For example, suppose I have both mechanical and electrical annotations and want to hide just the electrical. When I do this the electrical labels remain. I have attached an electrical annotation family for someone to play with.
If there is a different approach to what I want to achieve, I am open to any ideas.
ben
Sat, Dec 2, 2006 at 4:35:22 PM | Generic Annotations - Hiding Labels
mibzim
I can't open your file, so i might be missing the point here, but...
If its a generic annotation, its 2D and it therefore wouldn't really matter if you deleted them all from that view. If you wanted you could copy and paste them all into a new view that you just keep it hanging around till you need it.
Options for turning text labels on and off are limited, but you could add a visibility parameter to the label and turn it off there... you would end up with nothing showing though and don't know how you would select it. If you are after a generic annotation that inclueds both mechanical and electrical notes then this would be perfect for just turning off the electrical labels.
Sat, Dec 2, 2006 at 7:56:31 PM | Generic Annotations - Hiding Labels
benfischer
Sorry you could not open the file.
However your comments gave me some ideas for a couple of possible solutions. It too bad that labels cannot be grouped into the a subcatagory like lines/solids/voids can. At least that is what I am getting from your response.
I will play with this somemore and see what I can come up with. Thanks.
ben
Wed, May 16, 2007 at 4:17:31 PM | Generic Annotations - Hiding Labels
rchoutka
1 Stars: 1 Votes
Just an idea:   Make TWO  CryingElectrical and Mechanical) WORKSETS...?
Exporting Revit generic annotations to specific layers in Autocad. Help!
Wed, Nov 7, 2012 at 5:44:24 PM
Moving Annotation Symbols without moving objects
Mon, May 23, 2011 at 6:28:10 PM
Electrical Fixtures Lineweight
Mon, Dec 8, 2008 at 2:43:15 PM
nested generic annotations visible on site plan and roof plan
Thu, Feb 10, 2011 at 8:04:15 PM
Annotations accidentally snapped into linked dwg (Imported categories)
Tue, Jul 9, 2013 at 5:53:11 AM
Page generation time: 0.1664
