Forums >> Revit Building >> Technical Support >> wall sweep inside corner
Fri, Dec 1, 2006 at 10:37:41 AM | wall sweep inside corner
tomkriegshauser
while creating a wall sweep concrete sill for a wall reveal, revit 9.0 seems to have problems completing an inside corner. There doesn't appear to be any problems for revit 9.0 to complete an outside corner on the wall reveal. Any suggestions besides extending the sills and using 'join geometry' for the inside corner?
Tue, Dec 5, 2006 at 9:52:32 PM | wall sweep inside corner
eldados
eldados Avatar
4.5 Stars: 8 Votes
didn't come accross this b 4, can you post an image?
Integrator
KarelCAD
Mon, Dec 18, 2006 at 9:07:04 AM | wall sweep inside corner
tomkriegshauser
I think that I've solved the problem. If you want a wall sweep to miter at an inside corner, the wall or model element below it must be joined.
stacked wall sweep cleanup
Fri, Feb 12, 2010 at 9:11:19 AM
Wall Sweep at the Corner
Mon, Mar 25, 2013 at 1:20:45 PM
Anyone ever put a countertop on a wall as a sweep? Anyone?
Wed, Nov 15, 2006 at 3:42:51 PM
Corner Trim with Vertical Sweeps
Thu, Aug 31, 2017 at 2:32:51 PM
how to make a corner sweep
Mon, Apr 18, 2011 at 12:00:49 PM
Page generation time: 1.0986
