Forums >> General Discussion >> Revit ROI >> LOGO in drawing template
Fri, Dec 1, 2006 at 8:48:46 AM | LOGO in drawing template
2005Gill
Hi Everyone,
I am about to cross platform from ADT to Revit. I am about to start all over again but it will be worth it I am sure. I am getting my own style drawing template together in itd differnt sizes, Ai, A2 and A3. My question is that I use a house jpeg as my logo. Does anyone know how I can attach this in my heading box.
regards
Mark
Fri, Dec 1, 2006 at 9:35:32 AM | LOGO in drawing template
framerman
4 Stars: 13 Votes
File>Import>Image
load it onto your titleblock family(if I'm understanding you correctly), then when you import your titleblock, your jpeg will come with it.
you aren't by any chance importing all your sheet sizes into one project template are you? you could make a separate template file for each page size. the more sheets you have in your project file, the larger the file size is. you can clean up the file by purging though if that's the way you want to go.
Fri, Dec 1, 2006 at 9:52:02 AM | LOGO in drawing template
TomDorner
4.5 Stars: 25 Votes
To insert an image file [.jpg .png .bmp] go to File>Import/Link>Image
I would recommend doing a 'template' for each style or type of contruction and not load the 'titleblocks' into the template but keep them seperate to load in as required.  Having multiple 'templates' leads to great duplication of work especially when you first are starting off using Revit as you will discover many things along the way to add to your template.
[Edit: framerman beat me to hitting the submit button as I got sidetracked with a phone call]
Edited on: Fri, Dec 1, 2006 at 9:53:39 AM
Tom
Fri, Dec 1, 2006 at 10:38:45 AM | LOGO in drawing template
2005Gill
Thanks for coming back so promtly. I will try them out.
Thanks
Logo / Filled region in Drawing Sheet
Fri, May 7, 2010 at 4:22:30 PM
URGENT! blue logo revit 2012
Fri, Jun 14, 2013 at 9:45:05 AM
LINKING DRAWING INTO MOST RECENT TEMPLATE
Fri, Nov 14, 2008 at 6:08:45 AM
Changing a Template
Mon, Jul 8, 2013 at 2:44:42 PM
Creating and using sheets with company logo
Tue, Oct 6, 2015 at 3:22:53 AM
Page generation time: 1.1568
