Forums >> Community >> Newbies >> How are you all naming wall types
Thu, Nov 30, 2006 at 11:52:23 AM | How are you all naming wall types
weitgiest
Our firm just began using Revit.  I'm building timeshare units while my co-workers are building the skin, sweeps, verticle circulation ect.  I want to know how other firms are naming wall types.  I have 4 verions of walls w/ tileSad1) mtl stud 3 5/8", mr gyp bd 5/8", tile 1/2" - (2) gyp bd 5/8", mtl stud 3 5/8", mr gyp bd 5/8", tile 1/2" - (3) gyp bd 5/8", mtl stud 1 1/2", mr gyp bd 5/8", tile 1/2" (4) tile 1/2", gyp bd 5/8", mtl stud 6", mr gyp bd 5/8", tile 1/2" @ 38" high.
This is in addition to 10 other types of walls.  I was thinking of somehow tying them to the parition types sheet that will have the section detaill & UL assemblies.  But my PM suggested that would be too complicated.
How detailed should I get, if I have 3 types of tile would it be worth it to include that in the wall type?
Is a partial wall a unique wall type?
Thu, Nov 30, 2006 at 4:46:01 PM | How are you all naming wall types
jterrell
3 Stars: 5 Votes
We use a system like the following:
Usage - Framing Material - Framing Size - Exterior Finish - Interior Finish - Fire rating (if applicable)
For example, a 2x4 interior partion is labeled as
Interior - Wood - 2x4 - 5/8" Gyp - 5/8" Gyp
A two hour wall is labeled the same:
Interior - Wood - 2x4 - (2) 5/8" Gyp Board - (2) 5/8" Gyp Board - 2 Hour
That is for naming.
Just a thought though, you could just do a wall sweep of the tile on the walls you want. I did that once with slat board in a retail store.
Thu, Oct 11, 2007 at 2:24:37 PM | How are you all naming wall types
tim1424
How are you naming stacked wall types?  What is the typical method??
parameter naming conventions
Thu, Apr 2, 2015 at 8:44:13 PM
Door naming convention
Mon, Mar 17, 2008 at 4:14:49 PM
Stacked wall naming
Tue, Oct 23, 2007 at 4:46:56 PM
Stacked wall naming
Thu, Oct 11, 2007 at 2:35:16 PM
Stacked Walls
Mon, Mar 31, 2008 at 7:53:11 AM
Page generation time: 0.6007
