Forums >> Revit Building >> Technical Support >> Design Options - Efficiently Changing Option Visibility in Multiple Views
Wed, Nov 29, 2006 at 11:01:16 AM | Design Options - Efficiently Changing Option Visibility in Multiple Views
BarneyThomson
I'd like to display differnt views of my model and be able to quickly change visibility of options in all views.  It seems that it is required to go into each view and repeatedly modify the Design Options tab.  Anybody know a shortcut?
Thanks - Barney
Wed, Nov 29, 2006 at 11:26:41 AM | Design Options - Efficiently Changing Option Visibility in Multiple Views
Dgodfrey
4 Stars: 4 Votes
Unless I misunderstand your question, each view keeps it's visibility settings unique to that view and design options are intended to have their own view for each specific option. For example, you have a front entry garage and a side entry garage which would need 2 floor plans, one set to display the front entry(primary), and the other for the side entry condition. You may also require 2 separate sets of elevations, sections, framing, etc to show the different conditions that are affected. Just a warning however, design options can be very cumbersome if the options are extensive. By that i mean affecting roofs, structure, pieces that can affect other pieces as they all need to be included in the set which can cause you to pull you hair out if not really thought out. Sometimes it's just easier to do it the old fashioned way and save as a new file.
Multiple Design Options in One View
Tue, Apr 15, 2014 at 1:20:58 PM
Disassociate views from design options
Tue, Oct 6, 2015 at 12:56:55 PM
Design options issues
Thu, Mar 2, 2006 at 10:35:31 AM
Design Option Sharing
Mon, Dec 6, 2010 at 10:02:19 AM
12
Design Option view setting
Fri, May 16, 2014 at 8:02:11 PM
Page generation time: 2.3756
