Forums >> Revit Building >> Tips & Tricks >> Leaning Columns
Tue, Nov 9, 2004 at 10:04:40 PM | Leaning Columns
wess98
I have been looking for a way of rotating a circular column in Revit 6.1 to no avail........ ?
Tue, Nov 9, 2004 at 11:51:08 PM | RE: Leaning Columns
tmarchitects
Try looking sideways Andrew
Tue, Nov 9, 2004 at 11:52:12 PM | RE: Leaning Columns
tmarchitects
maybe try drawing line at angle in elevation and then extruding colomn to that angle
Wed, Nov 10, 2004 at 5:27:26 PM | RE: Leaning Columns
wess98
I found the way to do it by creating a family with extruded circle along a path. The path has the angle that is parametric along with the length. Currently looking for a way to make the circle radius parametric..........
Wed, Nov 10, 2004 at 6:57:50 PM | RE: Leaning Columns
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Ive made a similar type of column, however its rectangular. Created through a blend when you can specify the angle as well as the rectangle size. Let me know if you want to take a look as i'm sure you could edit it to have a circle in stead... Even have it taper if you like?
Wed, Nov 10, 2004 at 7:13:05 PM | RE: Leaning Columns
wess98
Is mr. spot jothan briggs other name? Yes that would be good to look at your rectangular column thanks Wes
Thu, Nov 11, 2004 at 1:29:00 AM | RE: Leaning Columns
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No? What gave you that idea...? Any way here's the file.
Sun, Nov 14, 2004 at 8:35:57 PM | RE: Leaning Columns
wess98
thanks Mr. Spot I've attached one I had done earlier for Dps. It may be of use but you probably already got one.
Tue, Apr 11, 2006 at 12:38:21 PM | RE: Leaning Columns
MrCampy
Mr. Spot, could you post the column that you have that tapers as well as leans? I am looking for a tapered beam and thought I could apply what you have done with the tapered and leaning column.
Fri, Sep 25, 2015 at 8:45:32 AM | Leaning Columns
richcollin
I understand there is a certain parameters that you could add up and matches to the length, howver,, you just need to work around on that to get the matchup.
http://caldwells.com/
2070 Newcomb Avenue,
Unit B, San Francisco,
CA 94124
Fri, Sep 25, 2015 at 9:01:10 AM | Leaning Columns
#11
richcollin,
I see that you just joined today and you have made two posts - both don't seem to make much sense.
You did notice that this thread was last posted in 2006?
Are you just bored?
Leaning columns
Sat, Jul 2, 2011 at 7:56:56 AM
need to lean columns to match shifting grid
Mon, Sep 24, 2007 at 1:20:52 PM
Leaning windows? (Windows in leaning walls?)
Fri, Aug 20, 2010 at 8:15:17 AM
inclined/sloping/leaning wall
Sat, Feb 25, 2006 at 6:33:30 PM
hidden columns
Fri, Mar 26, 2010 at 10:53:36 AM
Page generation time: 1.2111
