Forums >> Revit Building >> Technical Support >> hatch pattern
Wed, Nov 29, 2006 at 3:56:53 AM | hatch pattern
nandini
hi,
is there a way we can change the line weight and line type of a hatch pattern?
Thu, Jan 11, 2007 at 3:51:54 AM | hatch pattern
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
you can change only the line weight and type of the lines that delimit the hatch.
-paolo
Thu, Jan 11, 2007 at 3:54:01 AM | hatch pattern
Marc9999
what does that mean?
Fri, Jan 12, 2007 at 8:10:14 AM | hatch pattern
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
When you create an hatch you define its perimeter: only the perimeter lines are editable in line weight and in type.
you're welcome.
-paolo
Fri, Jan 12, 2007 at 11:21:16 AM | hatch pattern
Marc9999
sorry, i didn't mean to be rude.
can you change the lineweights of the existing hatches
 Also how do you go about creating new hatches?
thanks for your help
Fri, Jan 12, 2007 at 3:54:40 PM | hatch pattern
Westview
2.5 Stars: 2 Votes
Edit the fill patern and pick the lines, in the upper left corner are the different line types, change to the line type you want. Invissable lines will not show the border if you need to hide an object without the border showing.
Fri, Jan 12, 2007 at 10:37:17 PM | hatch pattern
puzzle
4 Stars: 10 Votes
To make new hatches there is a program called Hatchkit or you can edit an existing pat. file of an existing hatch.
Macca
Sunshine Coast
QLD Australia
Fri, Jan 12, 2007 at 11:24:36 PM | hatch pattern
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
If you want to edit your hatches, you have to know what symbols and numbers you will find inside stand for. For those who don't, there's an explanation inside the file revit.pat that is usually located in c:/Documents and settings/all users/application data/Autodesk/revit building x/training/metric and family templates/
There are 2 types of hatches: DRAFTING and MODEL, the first take the scale of the view, the last take the scale in the real world unit you specified in the .pat file.
The correct form for a single line hatch
-drafting
;%UNITS=MM
*name,description
;%TYPE=DRAFTING
angle of rotation of the origin axis took from the x-axis CCW, x coordinate of the origin, y coordinate of the origin, shifting from the origin of the next line, offset from the origin of the next line, first solid line [, if negative stands for the first  space, if 0 stands for a minimum lenght line such as a point, etc...]
-model
;%UNITS=MM
*name,description
;%TYPE=MODEL
it's a valid hatch also for Autocad user because the extra parameters %UNITS and %TYPE are preceeded by a ";" that makes them a comment for Autocad. You have to know that you can do a unique file with all your hatches of different types and load it every time you need it, without spending much time in selecting from a list of multiple .pat files.
hope this would be useful.
-paolo
Mon, Jan 15, 2007 at 7:31:47 PM | hatch pattern and linetypes from CAD
LIVE
Hi
I have a cosultants cad drawing which i am linking into my revit Drawing, and it contains hatches and linetypes containing text.  How can i get these to show up when linked in the Revit view.   the hatches show up, but are all over the place...what can i do?
 LIVE
Mon, Jan 15, 2007 at 10:06:38 PM | hatch pattern
mibzim
Revit does not support text in line types or text in hatch patterns, unless the text is drawn line by line into the hatch.
Also, u can define new hatch patterns by going to settings > fill patterns > new > custom > and import a .pat file.
Exporting hatch pattern
Thu, Sep 18, 2014 at 6:27:35 PM
hatch pattern not printing
Mon, May 8, 2017 at 12:56:51 PM
Hatch pattern
Tue, Jan 13, 2009 at 10:23:47 AM
Hatch 22- Curve Pattern
Wed, May 30, 2018 at 4:07:07 PM
custom hatch pattern without hatch editor
Wed, Jan 28, 2015 at 8:46:58 PM
Page generation time: 0.3247
