Forums >> Revit Building >> Technical Support >> Moving my Second and Third Floor Up
Tue, Nov 28, 2006 at 8:00:21 PM | Moving my Second and Third Floor Up
chadboetger
I need to move my Secong and Thrid Floor up 6".  I try and change the height by typing in the new height on the level marker, but this brings havok to the model.  I'd like to just be able to select the second and third floor with a window in an elevation view and move them up 6 inches.  Is there a way to do this????
Tue, Nov 28, 2006 at 9:27:49 PM | Moving my Second and Third Floor Up
mibzim
You should be able to simply change the RL of the level without any major problems. You can also just use the move tool when you have the elements selected.... what sorta havoc are you referring to?
Often the way you have modelled the building (walls, floors, roofs etc) in the first place will affect how easy it is to change things later on. Walls are a good example, and its usually easiest to make sure there are logical top and bottoms to these.
Moving an entire plan
Mon, Oct 29, 2012 at 7:31:51 AM
Revit Architecture 2013 - Moving Section Tag is Moving Referenced Detail
Wed, Nov 28, 2012 at 8:34:11 AM
Moving Floor Levels Independently
Thu, Feb 25, 2010 at 1:37:17 PM
Grid lines moving together in different floor plans
Mon, Sep 20, 2010 at 9:10:52 PM
Can't create camera or walkthrough on first floor but can on others. Why?
Wed, Nov 19, 2014 at 10:32:39 AM
Page generation time: 0.6055
