Forums >> Revit Building >> Technical Support >> Mass objects disappear in PDF
Tue, Nov 28, 2006 at 2:10:49 PM | Mass objects disappear in PDF
SPartin
Hello -- Looking for help in getting mass objects to print when I generate PDFs. I am attempting to create PDFS of individual 3D views (camera views) of specific rooms, using the "Shaded With Edges" option.  I have found that when the PDFs are generated, all of the mass objects that I've included in the scene disappear.  What am I doing wrong?  Thanks for any advice!
Tue, Nov 28, 2006 at 5:19:09 PM | Mass objects disappear in PDF
framerman
4 Stars: 13 Votes
You have to go into your visibility settings (VG or VV) and check the mass box in all your views you want to have the mass print. You can also create your mass into a roof, wall, or floor.
Edited on: Tue, Nov 28, 2006 at 5:19:49 PM
Wed, Nov 29, 2006 at 9:17:49 AM | Mass objects disappear in PDF
SPartin
That fixed the problem, Framerman.  Thanks for the help!
AUTOCAD 2006 - OBJECTS DISAPPEAR WHEN PLOTTING
Thu, Oct 13, 2005 at 4:38:12 PM
Chaning mass objects
Fri, May 8, 2009 at 3:41:08 AM
pdf printing problem
Fri, Jul 14, 2006 at 7:02:01 PM
Mass objects
Tue, Feb 6, 2007 at 7:57:18 PM
objects in view on sheet set not showing up in PDF
Wed, Jul 10, 2013 at 7:00:02 AM
Page generation time: 0.2347
