Forums >> Revit Structure >> Technical Support >> slow model performance
Mon, Nov 27, 2006 at 3:03:29 PM | slow model performance
anthonyforlong
Hi,
Can someone please give me some tips on how to speed up my model, The model is around 40MB but consists of a lot of structural beams (500+ per level, 14 floors.) and columns , I have positioned many of the beams using the beam system tool, which works great,
Unfortunatly when I need to move or modify a beam or wall etc the model realy hangs, after a few minutes i get a dialog asking telling me to remove coping, cuts on concrete mebers are igonred.
Is there a way to convert the floor beams into a family, would this increase the moels performace? any other suigestions would be greatly apreciated.
Thanks
Anthony
Mon, Nov 27, 2006 at 7:24:56 PM | slow model performance
anthonyforlong
Ok,
I may have found a work around, I'm set up a second project and using cut and past I've transfered all my beam systems into the second project. I've then linked this project back into the origional model, so far so good.
Anthony
Slow Model? – How to Increase Revit Performance
Thu, May 23, 2013 at 2:22:22 PM
Revit 2013 slow performance in citrix
Wed, Nov 5, 2014 at 11:03:13 AM
performance
Sun, Oct 17, 2010 at 10:24:35 PM
Question re: Model Performance vs modeling habits [ 1 2 ]
Fri, Jul 17, 2009 at 2:57:26 PM
20
topo surface causing slow performance
Fri, Feb 25, 2011 at 2:58:09 PM
Page generation time: 1.2991
