Forums >> Revit Building >> Technical Support >> diffrent wall thickness
Sat, Nov 25, 2006 at 10:08:00 AM | diffrent wall thickness
Unknown
Hello everybody,
 i will reconstruct an old building, but the walls are not parallel. For exampel the beginning of the wall have a thickness of 10 inches but the end is only 9 inches. How is it possible to make a wall with a diffrent wall thickness in the ground plan.
Can anyone help me?
Sat, Nov 25, 2006 at 11:23:26 AM | diffrent wall thickness
coreed
coreed Avatar
4 Stars: 16 Votes
try reviewing this link and look at wall.doc  document post by arnosondoval
it should help solve you problem. but it comes down to creating an in-place family, choose wall for your category, so that your mass behaves as a wall and then using extrusion to create the wall. that sort of summaries the link below. but i  would review all the posts in the link.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=1198
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Dec 6, 2006 at 3:23:00 AM | diffrent wall thickness
Unknown
Thanks a lot for your support!
Hatch patten lineweights for duct
Wed, Feb 10, 2010 at 11:17:25 AM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Wall Thickness variable
Tue, Apr 12, 2005 at 11:37:44 AM
Variable Thickness Wall?
Fri, Feb 10, 2017 at 6:09:58 PM
Revit 2013 - Window frame sweep with wall thickness
Wed, Nov 28, 2012 at 4:03:26 AM
Page generation time: 0.6015
