Forums >> Revit Building >> Technical Support >> line end in revit
Fri, Nov 24, 2006 at 3:34:50 PM | line end in revit
edupen
I have created a very thick line pattern and style to represent the fire rating of walls;it is made of dashed lines of different lenghts. when drawn the dashes are close together and they have this weird and horrible "round" end. how can i make revit to draw a line with rectangular ends? please help!!
Fri, Nov 24, 2006 at 6:06:52 PM | line end in revit
framerman
4 Stars: 13 Votes
sorry, but I don't think it's possible. there is...(sigh) a workaround. you can create a filled region. hope you don't have to do multiple times.
Sat, Nov 25, 2006 at 5:13:05 PM | line end in revit
ArchWestCY
4.5 Stars: 7 Votes
Why don't you just make a repeating detail? That is the way that Revit would want you to make that line.  I know it sounds weird for a line, but in AutoCAD the batt is a linetype.  In Revit batt is a repeating detail.  I don't remember all the steps, and I'm not at my station over the weekend.  You can look up Repeating Details in the Revit Help menu.
ArchWestCY
Tue, Jun 2, 2009 at 11:40:56 AM | line end in revit
romayama
Reg: FR plans
 Hi, I tried a repeating detail component with pattern unit - visually works but doesn't clean-up at the ends so I keep using thick lines for FR plans...
Revit Line ends
Fri, Dec 2, 2005 at 3:57:49 PM
Looking to make lines w/o rounding either end....
Tue, Jun 26, 2012 at 7:35:22 PM
Vertical bracing symbolic line ???
Tue, Jun 4, 2013 at 7:33:50 AM
View Title End
Tue, Feb 20, 2007 at 1:37:47 PM
Phantom section end
Thu, Apr 5, 2007 at 1:27:32 PM
Page generation time: 2.1972
