Forums >> Revit Building >> Technical Support >> exporting pdfs
Thu, Nov 23, 2006 at 11:57:56 PM | exporting pdfs
glenn1
Can anyone recommend a program that will export rvt files to pdf files to a correct scale? I've tried pdf995 and a few others and even when I set the correct scale and paper size for A3 they always come out too small. I've tried exporting dwf files as well and have the same problems.
Fri, Nov 24, 2006 at 1:01:26 AM | exporting pdfs
deboddy
5 Stars: 2 Votes
Glenn
 You don't need to export rvt files to pdf - just print whichever sheets you require and select adobe pdf as your printer - set up page sizes etc as per normal.
Deb
Fri, Nov 24, 2006 at 5:27:47 PM | exporting pdfs
carstenc
I think that it requires the PRO version of the ADOBE READER/ WRITER to do so, but I'm not sure, as I've always have had the PRO version installed.
Sat, Nov 25, 2006 at 1:35:29 AM | exporting pdfs
vector23
vector23 Avatar
2 Stars: 16 Votes
PDF is to DWF like CAD is to BIM
Sun, Nov 26, 2006 at 11:27:57 PM | exporting pdfs
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
there are about a billion threads on PDF's.
Check them out: http://www.revitcity.com/forums.php?action=search&keywords=pdf%20program
I find the DWF writer unreliable compared to PDF's.  I'd love to have more confidence in it, but it seems whenever i want to use it, it crashes.  Especially when attempting to do large multipage DWF's.
Regards,
Chris.
Thu, Nov 30, 2006 at 7:13:24 PM | exporting pdfs
glenn1
Thanks for your advice Mr Spot your tips are always helpful. I actually found a great pdf converter on the CD of the latest issue of PC AUTHORITY magazine at my local newsagent yesterday. It's called PDFCreator and took 2 minutes to install and worked perfectly straight away. It's good to solve a long time niggling problem like that in one simple step. I would recommend anyone with pdf export problems to go out and get the magazine and you won't regret. I do find it a bit difficult being up North of Brisbane here in Charters Towers but love using REVIT 99% of the time. I've used REVIT since Release 4.5 and get ill at the thought of doing any work for someone in Autocad by itself. I think I'd rather go mow lawns in the hot sun than use Autocad ever again.
Sat, Dec 2, 2006 at 6:36:55 PM | exporting pdfs
vector23
vector23 Avatar
2 Stars: 16 Votes
"i think"  dwf really shines with vector lines but pdf prolly better for raster..
if you want to send someone your sheets to look over - dwf  makes
that easier..  hot topics pdf and dwf..
Tue, Dec 5, 2006 at 4:19:05 AM | exporting pdfs
vector23
vector23 Avatar
2 Stars: 16 Votes
check it out folks-
Cadalyst AEC  Dec 1 2006"Following closely on Microsoft's debut yesterday of the long-awaited Windows Vista, Autodesk announced that DWF technology has been incorporated into the new operating system. This will allow Vista users to view DWF files without requiring additional software."  lol lol lol  and all the while i thought my horse was more reliable..
Tue, Dec 5, 2006 at 4:49:39 AM | exporting pdfs
bond
2.5 Stars: 3 Votes
the program i use is called bluebeam Pushbutton PDF, i have had no probs with it, used it for many years, simple and way easy, hope this helps
Tue, Dec 5, 2006 at 1:59:54 PM | exporting pdfs
vector23
vector23 Avatar
2 Stars: 16 Votes
bluebeam is a nice name for a horse..
3d PDFs
Fri, Jun 28, 2013 at 6:11:41 PM
How Large Can A Rendering Be Blown Up?
Wed, Dec 23, 2009 at 7:52:08 AM
Mass objects disappear in PDF
Tue, Nov 28, 2006 at 2:10:49 PM
Plotting to Remote OCE printer - help!!
Wed, Jul 13, 2005 at 2:30:18 PM
Keynotes Hyperlinks Urls DWFs PDFs
Thu, Aug 16, 2012 at 10:32:52 AM
Page generation time: 2.1386
