Forums >> Revit Building >> Technical Support >> Small DIM and ANGLE
Thu, Nov 23, 2006 at 1:29:20 PM | Small DIM and ANGLE
carstenc
When drawing a wall in Revit 9.1, the DIM and ANGLE text is very small. When trying to zoom, it just scales down along with the zoom. The problem hasn't always been there... At least not with Revit 8.1! Is there anything to do?
Thu, Nov 23, 2006 at 11:32:53 PM | Small DIM and ANGLE
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Are you talking about temporary dimensions or proper dimensions?
I'm assuming temporary dimensions...  I haven't noticed any difference, what resolution have you got your monitor set to?  Maybe its too high resolution for the size screen you are using?
Regards,
Chris.
Fri, Nov 24, 2006 at 11:33:01 AM | Small DIM and ANGLE
normanoid
I noticed the same thing when i use my 1280x720 projector as my "Primary Monitor". The active dimension text (any dimension attached to the currently selected object) become illegibly small and objects become very hard to click on to select; as if they have a 1 pixel width activation zone. If I switch my 1280x1024 Monitor back to the "Primary Monitor" the problem goes away - I think i have to reboot first though. I think it may be a problem with Revit at "Wide Screen" resolutions.
Edited on: Fri, Nov 24, 2006 at 11:33:25 AM
Fri, Nov 24, 2006 at 5:22:48 PM | Small DIM and ANGLE
carstenc
Hmm. My resolution is 1680x1050 and I have tried to make it smaller, but without results.
I've taken a screen print to show the problem. It beginning to irritate me, because it haven't always been doing that. I've also tried to reinstall revit, but without success!
I'm using a MacBook Pro with windows? Could it be the problem? I'll try install Revit 9.1 om my DELL this weekend to see if it also will get the same problem. I'm determinate to solve this problem, or at least find out the reason why :-)
But feel free to write suggestions or about experiences with this problem.
Fri, Nov 24, 2006 at 7:35:23 PM | Small DIM and ANGLE
normanoid
1680x1050 is a "widescreen" resolution. I think this is a bug (and a major pain in the posterior). It would be nice if Revit provided a way to set the size of this text.
Fri, Nov 24, 2006 at 8:05:38 PM | Small DIM and ANGLE
framerman
4 Stars: 13 Votes
I have no problem with my widescreen and the resolution is 1920 x 1200
Sat, Nov 25, 2006 at 5:48:35 AM | Small DIM and ANGLE
carstenc
Tried to install REVIT 9.1 on my DELL 15,4" wide screen today... No problem it showed up fine. My MacBook Pro is a 17" wide screen. The problem doesn't make any sense, when reading others experiences with this issue. It's obviously not a general fault in REVIT as I see it.
Mon, Jan 22, 2007 at 11:09:11 PM | Small DIM and ANGLE
NewBe
Did you every figure this out? I have the same issue on my 15" Macbook.
Temp Dim's are too small
Mon, Jul 30, 2007 at 10:36:05 PM
Getting A Perspective And Or Elevation in a Sm Room & Manual Override/input Dim
Thu, Aug 5, 2010 at 4:09:07 PM
Diminsion under dim line
Fri, May 18, 2007 at 10:10:30 AM
3d dim
Mon, Jun 16, 2008 at 4:09:16 PM
Settings for stringer
Thu, Oct 3, 2013 at 7:53:55 AM
Page generation time: 0.1675
