Forums >> Revit Building >> Technical Support >> Adding Level Thresholds to Doors
Thu, Nov 23, 2006 at 4:43:12 AM | Adding Level Thresholds to Doors
Spicoli
I am new to revit and require an external door with a level threshold but have found all the standard family doors have raised sills or no sills.
 I have been playing around with the family editor to get a better understanding of how it works and have managed to create a pre cast concrete sill and internal timber threshold strip which I added to a simple external door family. I have locked the shapes and added a parameter to enable them to be offset within the wall at the right place and can flex my family and change the position of the sill/threshold.
 My problem is that these two objects are outside the wall cut out area below the door so that when placed in my building model they overlap the wall structure.
 Does anyone know can I prioritise these objects as part of the door family to also cut trhough the wall?
Thu, Nov 23, 2006 at 11:47:33 PM | Adding Level Thresholds to Doors
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Either edit the opening cut in the family to incorporate this, or in the family use join geometry to tell these elements to join geometry with the actual wall.  Therefore when they overlap they should clean up.
HTH.
Regards,
Chris.
Visibility of Door Thresholds
Wed, Jul 1, 2009 at 9:50:17 AM
New 2016 Architectural Doors
Thu, Jan 28, 2016 at 2:33:56 PM
Adding Doors
Wed, Oct 17, 2012 at 1:01:15 PM
adding new intermediate levels
Sun, Sep 21, 2008 at 10:35:22 AM
Interior Remodel
Tue, Nov 29, 2005 at 4:54:08 PM
Page generation time: 0.4941
