Forums >> Revit Building >> Technical Support >> Dimensioning
Wed, Nov 22, 2006 at 9:43:18 AM | Dimensioning
brandyrosh
We are a Residential Design firm that likes to dimension to one side of the wall (core wall), for example left face to left face, etc...  any ideas how to do this?
 Thank you,
Brandy
American Gables, Inc.
Wed, Nov 22, 2006 at 10:11:07 AM | Dimensioning
framerman
4 Stars: 13 Votes
Yes, once you select dimension, you have many options on the bar above with your preferences for face of core among others.
Wed, Nov 22, 2006 at 10:30:22 AM | Dimensioning
brandyrosh
Thank you...but is it possible to dimension an entire wall with one side of the core face selected?  As I have done it, the walls are dimensioned as well, example:  the core wall of 3 1/2" is also dimensioned.
Thank you again,
American Gables
Wed, Nov 22, 2006 at 12:33:16 PM | Dimensioning
framerman
4 Stars: 13 Votes
yes, select modify, then select your dimension line, then select edit witness lines. click on the extension line you do not want and it should disappear. after that, you have to select a blank area of the screen to click to enter the modified dimension.
Dimensioning to the centerpoint of an arc
Tue, Jul 29, 2008 at 4:11:55 PM
Better Leaders For Dimensioning
Wed, Nov 24, 2010 at 7:52:57 AM
Dimensioning and then hiding objects?
Wed, Nov 7, 2012 at 2:34:01 PM
Isometric Views and Dimensioning
Mon, Feb 22, 2010 at 3:20:22 PM
Dimensioning railings
Fri, Jul 24, 2009 at 3:04:00 PM
Page generation time: 0.0471
