Forums >> Revit Building >> Technical Support >> Walls "sticking" together - DON'T WANT THAT
Tue, Nov 21, 2006 at 2:53:55 PM | Walls "sticking" together - DON'T WANT THAT
boydj
I have an existing drawing.  I am adding new walls adjacent to existing elements.Mainly a metal stud wall perpendicular to the end of an existing concrete wall.  When my new furred out wall gets remotely close to the existing concrete wall, the concrete wall 'jumps' and sticks to the new wall I am drawing.  The wall joins tool (even with "dont clean join"Winking does not help much.   I am using phases - I think this might have somehthing to do with it.
 How can I make it so walls don't stick together like this?  Walls trimming together and joining core materials is a nice thing for corners and such...but I dont want that here.
Thanks for any help
Tue, Nov 21, 2006 at 3:04:19 PM | Walls "sticking" together - DON'T WANT THAT
TomDorner
4.5 Stars: 25 Votes
Click on the wall you are not wanting to join.  There is a blue grip at each end of the wall, right click on the one end you are having trouble with and select "disallow join"  That wall end will now not interact with any others.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, Nov 21, 2006 at 3:10:31 PM | Walls "sticking" together - DON'T WANT THAT
boydj
thank you, thank you!
appreciate the help
Existing 12" wall w/4" brick-4" cavity-4" brick. Can't get plan brick to s
Thu, Apr 9, 2009 at 7:58:23 AM
new sheets - don't want them in my "drawing list" schedule
Fri, Jan 16, 2009 at 2:43:17 PM
Slopping Walls
Tue, Sep 27, 2005 at 12:07:30 PM
14
Specification column "Elevation at Bottom"
Wed, Jan 28, 2009 at 7:43:12 AM
14
I need to change my building levels from 0'-0" to 100'-0"
Sat, Sep 11, 2010 at 8:03:55 PM
12
Page generation time: 1.7218
