Forums >> Revit Building >> Technical Support >> save new template from project
Mon, Nov 20, 2006 at 11:17:48 PM | save new template from project
vector23
vector23 Avatar
2 Stars: 16 Votes
as you work in a project you make changes to the template.. like maybe you change the grid head symbol or
maybe you add new families etc.. how do you save just the new version of the template separate from the
project for use when starting your next project?
also how can i delete one word in this message box without the rest of it deleting as i type over it?
Tue, Nov 21, 2006 at 2:41:19 AM | save new template from project
timodevo
I don't know about your template question but, do you have 'overtype' on. Look for the button on you keyboard marked 'insert'  or 'ovt'. This should stop any changes you make to the text writing over your new text.
Tue, Nov 21, 2006 at 1:01:51 PM | save new template from project
vector23
vector23 Avatar
2 Stars: 16 Votes
i forgot about the silly insert key.. thanks
Tue, Nov 21, 2006 at 7:16:15 PM | save new template from project
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In your file menu use transfer project standards between your template file and the project you want to copy things from.  Then simply select the items you want to copy across.
You may then need to delete any extra settings from your template file that could now be incorrect duplicates.
HTH.
Regards,
Chris.
Template to Project
Tue, Jul 31, 2018 at 2:25:32 AM
Save an existing project file as a template file
Mon, Oct 26, 2009 at 1:11:47 PM
how to convert a template to project file in 2012
Fri, Aug 2, 2013 at 2:58:22 AM
Revit Template File from Project file .rvt to .rte
Sun, Apr 28, 2013 at 1:35:39 AM
Help! How to save a template file as an rvt file?
Wed, Aug 20, 2008 at 11:27:01 PM
Page generation time: 3.8604
