Forums >> Revit Building >> Technical Support >> Topography Quality
Mon, Nov 20, 2006 at 5:35:32 PM | Topography Quality
markdecker
The topography for Revit has been great for our firm until we realized that all of the time and effort we had put into adding points into our topography surface was somewhat all for not.  After looking at a few project’s topography, we realize that the created surface from Revit actually doesn’t always follow our points.  Has anyone noticed this situation and more importantly has anyone figured out how to configure Revit to follow all our points that we have painstakingly entered?  I have read in previous posts that this is not one of Revit's strong points but does anyone know which points Revit chooses to use and how to know this?  Or perhaps, what is the detail level the topography has when creating a surface? Any help would be greatly appreciated.
Mon, Nov 20, 2006 at 8:39:38 PM | Topography Quality
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I've never known revit to not follow the points that you define to the topography.
What I have noticed is Revit sometimes places the contour lines differently to how you'd like them to show.  That said the contours revit shows are still correct based on your supplied points.  You just have to put up with the contours being slightly differently represented.  Until we can define a topography by drawings the actual contours in revit this will be an issue.
But I don't believe it to be an accuracy issue.
Regards,
Chris.
Tue, Nov 21, 2006 at 11:41:04 AM | Topography Quality
markdecker
Thanks Mr. Spot for the response.  What do you think about this screen shot?  I understand that there might not be an answer to why Revit would not follow every point, but is there an ability to adjust the quality, or precision that Revit will have in regard to Topography?  Similar to this screen shot, we will also have severe indentations within a topography elevation, such as if you were to trace the outline of your hand with the topography, and Revit will ignore or avoid the indentation, as if Revit would just connect your fingertips as a posed to following your finger down to your knuckle and back to the end of the next finger.  Do you happen to know a way to trick Revit into following that indentation?  We have tried to bombard the notch with points but that seems to have no effect on the sculpting of the topography that Revit creates.  I know that this seems like a small inconvenience, however, when we create construction documents and the topography hits the building in different spots than we would like...could cause trouble.  Once again thanks for the help.
Tue, Nov 21, 2006 at 12:32:03 PM | Topography Quality
rodells
It is possible to use contours created in AutoCAD - 2D polylines in 3D space - then import the CAD drawing.
Position the import wherever you want in the Revit model, then go to the Site panel, pick the Toposurface option, then the Import option.   Pick the 'Import Instance' option, then pick on the imported CAD instance.   Revit faithfully models the site based on the contours.
This is anaccurate, easy and fast way to get data straight into Revit using the form we often get it from surveyors or civil consultants.    We use the same method to transfer in their data for property lines, utilities, etc.
Tue, Nov 21, 2006 at 7:23:38 PM | Topography Quality
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Quoting rodells from 2006-11-21 12:32:03
While this is a valid method, revits interpretation of the actual contours will still be different to the autocad definition.
Mark, just ignore the contour lines showing...  They mean nothing, they are simply an interpretation of revit as to how it thinks they should be represented and unfortunately there is no quality setting.  That said if your points are right the topography surface will be correct in elevation.  Even though you aren't getting that contour line showing that indent, you'll find the levels along that section will be correct as per your defined points.
HTH.
Regards,
Chris.
Thu, Dec 7, 2006 at 10:57:55 AM | Topography Quality
markdecker
Mr. Spot
Thanks again for the response.  Try this picture out.  Our biggest fear is that we are receiving topo from our surveyors, we are bringing those points into Revit, and then Revit is creating a topo skin that doesn't follow our entered points.  I know that our points are in Revit correctly because when I try to edit the topography they are correct, as shown in the image provided.  I can appreciate the accuracy in section and elevation, but our plan (and hopefully our 3D) needs to be correct too.
Thanks again for the help, its tough to answer these questions.
Thu, Dec 7, 2006 at 4:14:17 PM | markdecker
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Quoting markdecker from 2006-12-07 10:57:55
Mr. Spot
 Like I said before the actual modelling of the topography will be correct in 3D.  If the display of the contour lines in plan is a major issue, the only real solution is to turn them off and use the survey plan dwg as an overlay and display their contour lines instead.
HTH.
Regards,
Chris.
Fri, Jun 26, 2009 at 11:45:32 AM | Topography Quality
vrijaya
Can anyone tell me why this errors occurs in a topography? I atached the picture. This is a site generated with imported dwg splines...I am using Revit Architecture 2009. Pink lines are secondary lines.
Thank you.
Veronica.
Veronica
Fri, Jun 26, 2009 at 11:57:28 AM | Topography Quality
4 Stars: 205 Votes
Edit the Topo and increase the number of points in those zones...
Fri, Jun 26, 2009 at 12:03:41 PM | Topography Quality
Maybe you should examine the points on the imported splines.  I would look at the dwg in a 3d mode.  I think you will find teh problems are in that file.
Fri, Jun 26, 2009 at 12:25:08 PM | Typhoon
#11
vrijaya
Quoting Typhoon from 2009-06-26 11:57:28
Thanks a lot, it worked by increasing the number of points, but I still don't understand, why the Revit curves don't overlap the Autocad curves or points. The red lines are the dwg file. Is it possible to improve the quality of my toposurface somehow, I tried to use Simplify Surface tool but it did a slight difference.
I am new to Revit so I might ask things that are already obvious to the others. Smile
Veronica.
Veronica
Fri, Jun 26, 2009 at 12:35:09 PM | Topography Quality
#12
4 Stars: 205 Votes
Go to Settings>Site settings then you can increse the value you want....
Fri, Jun 26, 2009 at 12:37:06 PM | Topography Quality
#13
You said the cad drawing was splined.  Splines in CAD follow a set of rules based on where the points are.  Revit's topography lines too follow a set of rules based on where the points are but in this case, the points are probably few.  Remember... topography lines are either just a "drafter's interpolation of surveyed points or a CAD interpolation.  The points may be correct but between those points, two draftsmen could draw it differently.  Mor points - more accuracy.
Mon, Jun 29, 2009 at 6:10:52 AM | Topography Quality
#14
sagarkagathara
sagarkagathara Avatar
Mark,
You need to go to 'Settings'--> 'Site Settings' and  then adjust distance between 2 contours down to 1' (or whatever the minimum distance you want to see on your drawing).
 Now your contour lines should follow the points you entered.
Mon, Jun 29, 2009 at 6:52:06 AM | Topography Quality
#15
vrijaya
Thanks for your responses. I've managed it!
Veronica
walkthrough file in bad quality
Sun, Jul 11, 2010 at 1:27:52 PM
TOPOGRAPHY SPLIT PROBLEM
Mon, Sep 22, 2008 at 2:51:42 PM
Topography
Wed, Oct 19, 2016 at 6:19:21 AM
Topography dissapearing
Wed, Nov 7, 2012 at 2:46:15 PM
Font Quality
Wed, May 11, 2022 at 10:38:16 AM
Page generation time: 0.1875
