Forums >> Revit Building >> Technical Support >> Imported Raster Images Not Printin
Mon, Nov 20, 2006 at 1:54:05 PM | Imported Raster Images Not Printin
k4martin
Raster images (jpegs) that I've inserted will not print no matter what I do to adjust settings in the Print Set Up box.  I've already verified that the files show up in the raster images list.  Has anyone experienced this?  (F.Y.I  the images are part of a titleblock family that is loaded into the project).  Thanks!
Sun, May 4, 2008 at 3:52:34 PM | Imported Raster Images Not Printin
kunal1983
hey there
 i have the same problem, iv placed a sky image in my elevation and it wont let me print to PDF
dont know y
Mon, May 5, 2008 at 2:07:26 AM | Imported Raster Images Not Printin
sharath
use default sky, then take camera view and align it to elevation  then render it... or else export renderd image as png or jpeg to photo shop png is good u dont hav to edit...white space.. then put the sky..
http://www.revittut.blogspot.com/
Mon, May 5, 2008 at 2:08:27 AM | Imported Raster Images Not Printin
sharath
U can also use decal option it that u ll get picture in 3d but u can see only when rendered
Mon, May 5, 2008 at 3:29:04 AM | Imported Raster Images Not Printin
kunal1983
thanks,
but im printing to a PDF every time i export the PDF to photoshop i lose the image quality, i need to have a title box on the page, is there any other way
 thanks, kunal
Sat, Sep 27, 2008 at 5:04:19 PM | Imported Raster Images Not Printin
Sean
I had the same problem and i had to import the raster image into the sheet space and not the view drawing.  I think the problem was wen I imported it I had to rotate the image so i did the rotating and sizing in another program before importing it.  see if this helps.
Tue, Aug 11, 2009 at 4:37:04 PM | Imported Raster Images Not Printin
revking
I have the same damm problem. Raster image is on the sheet. I can't even get to show up in print preview, sometimes I get a partial image a ka a coner of the entire image.  Auto desk for you They screwed auto cad up relase after release, it will be the same for Revit too bad because I loved 2009. I am going to try export to dwf or dwg to print. something ought to work. I thought they would fix this in the service pack NO LUCK
Tue, Sep 22, 2009 at 10:33:06 AM | Imported Raster Images Not Printing
gmosebach
any luck with this yet revking, I'm having the same problem you described. (using structure 2010)
worked fine in 2009 but project got upgraded to 2010 by architect and now.....
"Raster image is on the sheet,  I can't even get to show up in print preview."
thanks
Tue, Sep 22, 2009 at 10:49:30 AM | Imported Raster Images Not Printin
Read some of the similar linked threads shown below.  They may contain your answer.
Wed, Sep 23, 2009 at 3:39:09 PM | Imported Raster Images Not Printin
gmosebach
FYI - Found out we needed to switch a setting in our (KIP) plotter preferences.  switched from KIP GL to KIP Script
http://forums.augi.com/showthread.php?t=106939&page=2
Raster Images
Tue, Jan 19, 2010 at 9:24:57 PM
Importing Raster Images
Tue, Jun 13, 2006 at 12:55:39 PM
Raster Image Content Blank-2010
Fri, Aug 28, 2009 at 12:39:02 PM
Linking raster images into revit 2008... Do Not Update?
Fri, Apr 4, 2008 at 8:11:43 AM
Issues with Importing Images into Revit - Help needed please
Mon, Jul 10, 2006 at 9:31:35 AM
Page generation time: 4.7847
