23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Can't adjust Joist line weights
I'm working in plan view placing beams and joist using the appropriate usage (i.e. Girder, Joist, Purlin, etc). Not being pleased with the line weights, I'm trying to reassign a different line weight for Joists in the "Object Styles" dialogue pulldown. However, any change I make won't take effect in my plan view. I'm currently working in Revit Structure 3. I don't recall a problem when doing attempting the same line weight change when working with Revit Structure 2. Any ideas?
bump . . . I'm having the same problem in RS 2009. This is an old post. Surely we have a solution by now. I'm still working my way thru the search results.
I do not use structure but in architecture, you can expand the object category under Settings/object styles/ model objects and there are more line controls listed. Perhaps what you need is in this expanded area. Just click on the menu tree branch on the left.
Actually, I just figured it out and haven't had the time to post it here yet. In the Object Styles window, on the Model Object tab, Select Structural Framing / Web Joist Change the Projection Line Weight and Line Type as desired. That will produce the desired effect in Plan Views (Course View). Ta Da!!
This appears to not work in section. Bummer.
You need to better explain yopur problem rather than using this very old post.
Export to dwg - Line weights |
Mon, Oct 23, 2006 at 2:35:25 AM
Sloped joist line type |
Thu, Nov 25, 2010 at 12:25:02 PM
Line weights reverting to standard |
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights |
Wed, Jan 16, 2013 at 3:33:32 PM
exterior elevations and line weights |
Fri, Jul 20, 2007 at 12:06:07 PM
