15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Trouble with Shodows in interiors
gstabsactive Joined Fri, Sep 2, 20051 PostsNo rating I have just a model of a room and I have set it up so you can see the muntins of the window on the floor. While setting the sun's location to get the right look I have the ceilings turned off. When I turn the ceilings back on the sun changes it's location or else it just doesn't shine thru the window anymore. Any ideas as to what I'm doing wrong or if it is a glich????????????This user is offline Fri, Nov 17, 2006 at 7:34:07 PM | Trouble with Shadows #2
ddvbactive Joined Thu, Nov 16, 20061 PostsNo rating Someone should help with this issue because I'm having the same. When I put my Camera out of the building in Revit 9.0 the shadows project well into the building and throughout the windows, but when with the same view I orbit inside the building, the shadows are gone! PLEASE HELP US!!!!
Me again... I have noticed that this issue only happens when I'm standing under the shadow of the interior of the building. When I put the camera source near a window where the sunlight comes through, I can see the sun projected inside, but if I move a bit out of the sun's reach, the sun/shadow projection disapears. I don't know what to do. Does anyone have a clue? Thanks.
Splitting Master Model into separate Interiors and Docs Models |
Wed, Aug 21, 2013 at 7:24:50 AM
Gray Gloomy Interiors Revit 2010 |
Mon, Aug 9, 2010 at 12:35:46 AM
Interiors specialist & the drywall "cover-up" |
Thu, Jun 11, 2015 at 2:58:03 PM
Bellini Chair |
Sat, Nov 18, 2006 at 8:15:43 PM
Radiation troubles |
Mon, Jul 18, 2005 at 8:46:36 PM
