10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Wall wraps
5 Posts No Rating |
I need the brick to wrap at the windows. When I go into the wall edit assembly box it won't let me check the wrap box. Please help.
Click on the wall then the wall properties button, click on edit, click on wrapping at inserts then coose exterior and it should work.....HOWEVER - go on to the edit structure and make sure the wraps button is checked for your brick & whatever else needs to wrap.
5 Posts No Rating |
tHANKS FOR THE HELP. i FOUND OUT WHAT i WAS DOING WRONG. i WAS PUTTING THE EXT. FACE BRICK ON THE INSIDE OF THE CORE BOUNDRY. wHEN i MOVED ABOVE THE CORE BOUNDRY IN EDIT ASSEMLY THE BRICK WRAPPED.
50 Posts No Rating |
I am having a similiar problem... i have a double framed 12" wide wall type. when i insert an arch opening only 1 side of the stud layers will return. all the boxes are checked to wrap. ????
yeah, i got it to work.. i just changed the wrap at inserts from interior to both.
Wall Wraps |
Fri, Oct 17, 2008 at 1:17:25 PM
13
Wall wraps at inserts |
Tue, Jun 28, 2016 at 3:50:38 PM
Door deletes when I edit wall type. |
Mon, May 1, 2006 at 2:27:03 PM
wall wraps |
Tue, Jan 31, 2006 at 4:47:15 AM
Wall join and wraps |
Wed, Jan 22, 2014 at 7:24:53 AM
