Forums >> General Discussion >> Wishlist >> Conditional statements in families.
Thu, Nov 16, 2006 at 2:20:30 PM | Conditional statements in families.
If ... then x=y
Thu, Nov 16, 2006 at 5:49:36 PM | Conditional statements in families.
bolandereric
What are you trying to say.
Fri, Nov 17, 2006 at 6:44:50 AM | Conditional statements in families.
Self explanitory - If "you have ever used conditional statements" then "you would know what I mean" otherwise "check it out".
Fri, Nov 17, 2006 at 7:19:18 AM | Conditional statements in families.
framerman
4 Stars: 13 Votes
I still don't know what you mean.
Fri, Nov 17, 2006 at 7:54:06 AM | Conditional statements in families.
coreed
coreed Avatar
4 Stars: 16 Votes
i agree with you framerman
From a previous post by Tom Dorner
Below is the Revit help file which explains it pretty well.
You can use conditional statements in formulas to define actions in a family that depend on the state of other parameters. With conditional statements, the software enters values for a parameter based on whether a specified condition is satisfied. Conditional statements are useful in certain circumstances; however, they make families more complex and should be used only when necessary.
For most type parameters, conditional statements are unnecessary, because the type parameter itself is like a conditional statement: If this is the type, then set this parameter to a specified value. Instance parameters are a more productive place to use conditional statements, particularly when they are used to set a parameter that does not vary continuously.
Syntax for Conditional Statements
A conditional statement uses this structure: IF (<condition>, <result-if-true>, <result-if-false>Winking
This means that the values entered for the parameter depend on whether the condition is satisfied (true) or not satisfied (false). If the condition is true, the software returns the true value. If the condition is false, it returns the false value.
Conditional statements can contain numeric values, numeric parameter names, and Yes/No parameters. You can use the following comparisons in a condition: <, >, =. You can also use Boolean operators with a conditional statement: AND, OR, NOT. Currently, <= and >= are not implemented. To express such a comparison, you can use a logical NOT. For example, a<=b can be entered as NOT(a>b).
The following are sample formulas that use conditional statements.
Simple IF: =IF (Length < 3000mm, 200mm, 300mm)
IF with a text parameter: =IF (Length > 35', “String1”, “String2&rdquoWinking
IF with logical AND: =IF ( AND (x = 1 , y = 2), 8 , 3 )
IF with logical OR: =IF ( OR ( A = 1 , B = 3 ) , 8 , 3 )
Embedded IF statements: =IF ( Length < 35' , 2' 6" , IF ( Length < 45' , 3' , IF ( Length < 55' , 5' , 8' ) ) )
IF with Yes/No condition: =Length > 40 (Note that both the condition and the results are implied.)
-----------------------------------Tom www.reviteer.com http://blog.reviteer.com
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, May 14, 2008 at 2:02:37 PM | Conditional statements in families.
lunchtrayrider
3.5 Stars: 7 Votes
IF WWHub=Wiseguy,we should laugh,we should still smirk a little
Wed, May 14, 2008 at 4:27:34 PM | Conditional statements in families.
I smirk when I read that old post.
Thu, May 15, 2008 at 5:35:41 AM | WWHub
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting WWHub from 2008-05-14 16:27:34
"I smirk when I read that old post."
wow!! me too!!
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Minimum / Maximum Parameters
Fri, Nov 3, 2006 at 2:04:26 PM
Formula to not exceed value in family
Tue, May 20, 2008 at 12:34:26 PM
Conditional Statements in Formulas
Wed, Jun 21, 2017 at 3:50:17 AM
Parameter Formula
Tue, Apr 3, 2007 at 8:57:05 PM
Formula - 2 x 'if' conditions in one line?
Thu, Dec 1, 2016 at 7:18:33 AM
Page generation time: 3.8480
