Forums >> Community >> The Studio >> ceiling cornice
Sun, Nov 7, 2004 at 7:59:33 PM | ceiling cornice
iPang
Does anyone could tech me how to make a ceiling cornice? Thx.
Sun, Nov 7, 2004 at 9:08:32 PM | RE: ceiling cornice
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
There are two methods. 1. (if you want to include the cornice on all walls of a certain type). Profile in wall family. Create a new family using the metric profile - hosted template. Now draw the profile of the cornice you wish to use. Note: it must be closed ie: a complete loop. There may also be a cornice already created that you could use... Now load the family into the project. Select a wall that you wish to apply the cornice to. Go to its properties, select edit/new Under structure choose edit. Select preview and change to the section view. Now select sweeps-->add Now select the profile, material and locate it 0 offset from top on the interior side of the wall. Now click okay until you close all windows and there you go. 2. For a single instance (ie: not all walls of a certain type only those selected) Go to a 3D or elevation view of the wall. Go to your modelling tab and select host sweep-->wall sweep. Setup the appropriate profile for your sweep and then select where on the wall or walls to locate it...
Mon, Nov 8, 2004 at 1:51:17 AM | RE: ceiling cornice
iPang
Can't we make a cornice like host-sweep in Modelling tab?
Mon, Nov 8, 2004 at 3:58:58 PM | RE: ceiling cornice
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes of course. That was option 2...
Cornice on exterior wall disappears when I place window 2' above it?!
Mon, Nov 28, 2011 at 2:22:07 PM
Advice - Wall Cornice
Fri, Feb 3, 2012 at 12:05:51 PM
3d Cornice & Skirting Advice
Mon, Nov 10, 2014 at 11:41:34 PM
how to add cornice to the roof ?
Tue, Aug 22, 2017 at 3:17:59 AM
gable return cornice
Thu, Aug 8, 2013 at 3:05:49 PM
Page generation time: 0.2852
