Forums >> Revit Building >> Technical Support >> linework tool - showing through?
Wed, Nov 15, 2006 at 10:44:41 PM | linework tool - showing through?
stritch
When I use the linework tool in plan the line I select shows though other objects above it - for example: I have a void through which I can see half of the stairs on the level below, I want to grey the stairs out but when I use the linework tool the half of the stairs that is hidden by the slab shows through. I am I doing something wrong? Is there a different way to do this?
Thu, Nov 16, 2006 at 11:35:30 AM | linework tool - showing through?
laurabh
Use the Visibility/Graphic overrides.  (View -> Visibility/Graphics OR type in VG).  Change the color for stairs to gray.  It will only affect the appearance of the stairs in the current view.
Thu, Nov 16, 2006 at 4:20:55 PM | linework tool - showing through?
stritch
the problem with that is I also have stairs on this level that I want to keep black. VG override changes all the stairs - is there a way to make it specific to a single component?
linework tool - original showing up next time I open revit project
Fri, Aug 8, 2014 at 2:18:21 PM
Linework tool issue
Mon, Sep 26, 2011 at 3:20:44 PM
Linework Tool (LW)
Thu, Mar 11, 2010 at 4:34:30 PM
Linework Tool
Mon, Jul 28, 2014 at 8:42:22 AM
linework tool
Thu, Mar 6, 2008 at 12:19:34 PM
Page generation time: 0.3040
