Forums >> Revit Building >> Technical Support >> Door Swings in reflected ceiling plans
Wed, Nov 15, 2006 at 7:18:40 PM | Door Swings in reflected ceiling plans
johnda
Can anyone please help. I'm trying to add linework for door swing & door panel that appear in reflected ceiling plans. I would like these elements to be apart of my door family. I've tried various lines (model & symbolic) at various levels (floor & above door head) but unforetunately no luck. The linework above door head just makes the family taller and RCPlan needs to cut thru the door family for any of it to appear, then you get door frames & wall segments missing. ??
Fri, Nov 17, 2006 at 1:04:50 AM | Door Swings in reflected ceiling plans
Erik
Have you tried the linework tool? Adjust the view range so you see the door swing, use the linework tool and change the linestyle for the swing for all the doors (tidious if you have lots of doors) Adjust view range back you might have the result you wanted.  Does that help?
Sun, Nov 19, 2006 at 2:20:19 AM | Door Swings in reflected ceiling plans
dianajohn
(dianajohn = johnda @ home)
Thanks Erik for you input, I'm attaching a copy of the door family, I do have symbolic lines for the door swing that apperars in the floor plans, & I have tried using model lines on a ref plane above the door head( say 2400 afl) with a celiling view height of 2300. This increases the overall height of the family to 2400h & in reflected ceiling plan the door frame appears to be sectioned instead of seeing a wall (no door frame) & door swing.
Ceiling Plans with Doors showing
Fri, Apr 25, 2008 at 10:03:38 AM
Reflected Ceiling Plans
Mon, Aug 22, 2011 at 9:57:26 AM
door and/or window openings in reflected ceiling plans
Wed, Nov 11, 2015 at 4:28:24 PM
How to load back the Reflected Ceiling Plans into the Project Browser?
Tue, Jun 8, 2004 at 5:41:39 PM
Cannot open reflected ceiling plan
Fri, Jan 9, 2009 at 2:23:07 PM
Page generation time: 0.8021
