Forums >> Revit Building >> Technical Support >> Topography Cut/Fill Schedule
Wed, Nov 15, 2006 at 3:22:48 PM | Topography Cut/Fill Schedule
DavidCrotty
I am using R8.1 and have created a topography schedule that I want to use to calculate cut/fill.
I created the topography with the Phase Created: Existing and Phased Demolished: None.
I created a pad with Phase Created: New Construction and Phased Demolished None.
I made the cut/fill portion of the topography with Phase Created: Existing and Phase Demolished: New Construction.
I have changed the View Properties with Phase Filter: Show Previous + New and Phase: New Construction
The Topography Schedule is set up to show: Name, Projected Area, Surface Area, Cut, Fill, and Net cut/fill. The columns: Cut, Fill, and Net cut/fill indicate a value of 0 (and my cut fill should be significant). The other columns seem to be working correctly.
 Any suggestions why the Cut & Fill are not working in the schedule would be much appreciated.
Thu, Nov 16, 2006 at 11:15:51 AM | Topography Cut/Fill Schedule
DavidCrotty
After working on this issue more I found a solution that appears to be working. The basic problem I had was that I was not using the Graded Region function. Here is what I found (all steps may not be necessary, but the end result looks correct):
1.Link the dwg topo file in the view Floor Plan: Site Plan
2. Create a Toposurface then place the created topo on Phase: Existing and Name the Element "Existing Topo"
3. Create a Graded Region (select copy internal points) hit Select and pick the topo surface. This will create a duplicate topo, name this topo "Proposed Topo"
4. Set the Phase Filter to: Show New in the View Properties dialog box.
5. Add the required Pads on the correct floor plan
This is a brief description of the process that appears to work. I guess I have to just trust the numbers that show up in the schedule, a little reassurance in their accuracy would make me feel better. If anyone has a better way to do this I would be interested in hearing about it.
Topography - Cut and Fill for Graded Region
Fri, Feb 4, 2011 at 11:31:15 AM
Revit Topography schedule - several issues!
Mon, Jul 14, 2014 at 8:59:00 AM
Topography Schedules and reporting Pad cut/fill.
Sun, May 7, 2006 at 6:39:59 PM
CUT AND FILL - PADS WHICH DO NOT SHOW C&F VOLUME ON A SCHEDULE
Tue, Feb 13, 2018 at 4:37:06 AM
cut / fill volume does not appear in schedule
Sun, Aug 29, 2010 at 8:47:28 AM
Page generation time: 0.6047
