Forums >> Revit Structure >> Technical Support >> Errors while trying to Copy Monitor
Wed, Nov 15, 2006 at 8:55:06 AM | Errors while trying to Copy Monitor
UKJon
Hello Everyone,
I'm a nuwbie and probably doing something wrong.
When copy/monitoring a file that an architect has made, I am copy/monitoring the grids, elev, columns and walls.  When copying the walls I get 45 errors that must be discarded.  Among the errors are "Can't keep elements joined", "elevation path is invalid", "line is too short", "Can't make extrusion", "Highlighted walls overlap".
Is this something I'm doing incorrectly or are the architect drawings not created right?  Also, is there any way to make the copy/monitor options for walls, columns, etc. to always copy the items like the original or do you have to set that up for every job.
Thanks,
Jon
Errors when Copy/Monitoring Levels
Tue, Jan 30, 2018 at 4:27:02 PM
Copy/Monitor walls
Tue, Apr 2, 2013 at 10:14:23 AM
Copy Original Type Not Available in Copy Monitor Options Dialogue
Fri, Nov 6, 2015 at 2:16:27 PM
Can't Get Copy Monitor to Work for Grids and Levels
Fri, Feb 21, 2014 at 4:55:28 PM
Copy/Monitor Lights to Revit Architecture 2012
Wed, Oct 17, 2012 at 3:05:52 PM
Page generation time: 0.6453
