Forums >> Revit Building >> Technical Support >> viewports
Sat, Nov 6, 2004 at 12:20:13 PM | viewports
marctsap
Newbie on board!! How do (or can I) crop a viewport on my drawings sheet or somehow change the viewport so that I only show a part of a floor plan.
Sat, Nov 6, 2004 at 11:33:10 PM | RE: viewports
pi_arch
hi, in ur floor plan, right click and click view properties, ther u have crop region click to select that. It would show u the crop box on the drawing. U can now pull the blue dots to the area u want in the plan to print or work on. then on the sheet, that after u have loaded a sheet u can just drag that floor plan from the properties bar on the sheet for it to appear on the sheet BUt now i have a question, can some one help me with this. If i want to print a number of plans ... say have 14 floor plans to print on different sheet each, but i want the plans to fit at the same position for each one how do i do that?... is there anything like a template? i mean i set up one format on sheet for say a plan a elevation / section and can repeat the same on other sheets at those poisitions only? by only changing the Ground floor plan to say first floor or elevation A to elevation B?? can some one help me with that? now thats in one project itself..
Sun, Nov 7, 2004 at 7:07:14 PM | RE: viewports
ale02
ale02 Avatar
3 Stars: 3 Votes
pi_arch, I believe you are talking about marco rather than templete in this case. In Revit, you can setup a templete which everytime it open up 14 seperate sheets (pre-set) but I believe it don't have the capabilities to direct the copy action of all the different levels of plan (eventhough identical) to each separate sheets. I think if you want to have every plan at the same location, properly you have to create an same insertion point at each sheets and drag drop the plans on to the sheets
Life is never easy but nor it should be complex. Just stay simple Smile
Edit Visibility Graphics in multiple viewports?
Mon, Nov 28, 2011 at 1:37:05 PM
Viewports orginizing on sheet
Mon, Apr 18, 2016 at 10:45:14 AM
Room Plans, Non Rectangular viewports from Revit 2014 and Python Shell
Thu, May 23, 2013 at 2:28:19 PM
many viewports
Mon, Aug 24, 2009 at 9:17:12 AM
Revit FBX to 3D Max 2011 causes black or unresponsive viewports
Fri, Jan 13, 2012 at 11:29:51 AM
Page generation time: 1.8262
