Forums >> Revit Building >> Technical Support >> .shx fonts
Tue, Nov 14, 2006 at 3:16:19 PM | .shx fonts
CuriousAboutRevit
1 Stars: 1 Votes
Hi guys! I was wondering if ACAD .shx fonts are combatible with REVIT and how you would import it into the project. Then how would you make sure that this font was available to you for every project you start without having to re-load it every time.
Tue, Nov 14, 2006 at 4:22:38 PM | .shx fonts
ArchWestCY
4.5 Stars: 7 Votes
Shape fonts are Autodesk fonts made for use with AutoCAD.  So, it only makes since that .shx fonts would work with Revit.  Well, they don't.  I have gone around with the tech support at Autodesk about this one.  From what I understand there is no immediate plan to incorporate .shx fonts into Revit.
I have found some Truetype fonts that are very similar to the .shx fonts that we used to use.  What .shx fonts are you trying to load?
If you setup your text styles in your template then they will be there for every job you start with that template.
ArchWestCY
Tue, Mar 20, 2007 at 11:52:21 AM | .shx fonts
Detour
1 Stars: 1 Votes
I am trying to find a font similar to Archstyl.shx.  Does anyone know one?  Thanks
Fri, May 29, 2009 at 8:01:01 AM | .shx fonts
Bimman
Bimman Avatar
1 Stars: 2 Votes
DID YOU HAVE ANY LUCK FINDING SOMETHING SIMILAR TO ARCHSTYLE
PWD
Fri, May 29, 2009 at 8:18:06 AM | .shx fonts
Read the SIMILAR links at the bottom of this window: Revit fonts that match AutoCad .shx fonts
Fri, May 29, 2009 at 10:36:25 AM | .shx fonts
Bimman
Bimman Avatar
1 Stars: 2 Votes
thanks,
I found archtext.ttf it is a really close match to archstyl.shx.  it is supposed to be a crossover for archstyl.
PWD
export ttf to shx fonts
Wed, Apr 8, 2009 at 12:04:05 PM
shx fonts please help
Sat, Jun 17, 2006 at 10:51:57 PM
Importing Old Fonts .shx
Fri, Mar 31, 2006 at 11:09:29 AM
TTF Fonts for Revit
Mon, Jun 5, 2006 at 3:38:49 PM
Thu, Jun 14, 2007 at 3:52:14 PM
Page generation time: 0.9943
