Forums >> Revit Building >> Technical Support >> Plotting HELP!!
Tue, Nov 14, 2006 at 2:46:40 PM | Plotting HELP!!
CuriousAboutRevit
1 Stars: 1 Votes
Hi guys! I need to know how some things affect plotting in Revit. When "thin lines" are turned on....does this affect the way it will be plotted?? also...how about model "lines" (created using the "line" command), will these show up during a plot...or are they invisible to plotting?
How does the lineweight system of 1-16 correlate with the real life pen weights (mm)??
Tue, Nov 14, 2006 at 3:13:10 PM | Plotting HELP!!
framerman
4 Stars: 13 Votes
Thin lines are just for viewing purposes. It doesn't affect plotting. Model lines will show up in plotting. You should find all your answers to the line weight question under settings>line weights.
plotting to a plotting service plotter with a prn file
Wed, Jun 4, 2008 at 1:14:56 PM
Plotting PDF's
Tue, Jul 21, 2009 at 4:18:05 PM
Plotting
Fri, Apr 28, 2006 at 8:31:02 PM
plotting problem
Wed, Dec 22, 2004 at 3:44:51 PM
Lines plotting half toned
Fri, Jun 15, 2012 at 10:42:01 AM
Page generation time: 0.6223
