Forums >> Revit Building >> Technical Support >> " an unknown error occurred while accessing ....central.rvt"
Tue, Nov 14, 2006 at 12:07:30 PM | " an unknown error occurred while accessing ....central.rvt"
SEHRLICH
Has anyone got an error: " an unknown error occurred while accessing....central.rvt" while trying to save to central?
I try to create a new local  from the central file and still you can't not save to central with that new local file.
 any suggestions?
Tue, Nov 14, 2006 at 4:33:41 PM | " an unknown error occurred while accessing ....central.rvt"
eldados
eldados Avatar
4.5 Stars: 8 Votes
try to open the file with Audit option, let Revit try to fix it and save as central...
Integrator
KarelCAD
Thu, Nov 4, 2010 at 9:47:07 AM | " an unknown error occurred while accessing ....central.rvt"
johnsonsara
I'm getting the same message in 2011.  I've tried audit and purge.  I've made local files before in 2011 and they work fine.  Please help! Thanks!
Thu, Nov 4, 2010 at 10:13:14 AM | " an unknown error occurred while accessing ....central.rvt"
As eldados said, try to audit the file and create a new central.  If that doesn't work and if your local is up to date, create a new central from that.  Either way, you should be making new local afterwards.
Fri, Nov 5, 2010 at 9:05:15 PM | " an unknown error occurred while accessing ....central.rvt"
johnsonsara
I had tried audit, purge...making new central and locals...I finally called our tech support.  The problem ended up being a permissions issue with the project folder.  I made a brand new project folder and copied every file over separately, not just moving all the subfolders because those too had a permission issue.  I made a new local file and everything worked perfectly!  So this was NOT a revit problem.
Wed, Dec 11, 2013 at 4:53:54 PM | " an unknown error occurred while accessing ....central.rvt"
Goos1488
If you're on a server, it is possible that you are just out of space on your storage drive. That happened to me. Add more space or free some up and you should be good to go.
Thu, Dec 12, 2013 at 8:55:10 AM | " an unknown error occurred while accessing ....central.rvt"
I think the original poster probably solved his problem .... 3 THREE years ago.
Please pay attention to the post date.
Tue, Feb 11, 2014 at 5:27:57 AM | " an unknown error occurred while accessing ....central.rvt"
keeza09
this happened to me as well and it turned out it was the permissions folder too
Tue, Oct 10, 2017 at 6:14:57 PM | " an unknown error occurred while accessing ....central.rvt"
raja15
Hi guys,
I realise this post is very old - but just wondering if anyone remembers exactly what folder permissions were preventing the save?
We've got the same issue at the moment & after about a months worth of Autodek support & our own IT guys investigating, we still can't work out what's going on.
Essentially we have 6 computers in the office. Whenever a file is workshared we could have up to 4 people working on it at the same time. 2 of those computers are encountering these errors (not consistently I might add) and we are trying to work out why some computers are fine and some aren't.
Really appreciate any insight or information!
Thanks in advance,
PS. Running Revit 2017 on all computers.
Edited on: Tue, Oct 10, 2017 at 6:20:26 PM
Wed, Oct 11, 2017 at 12:53:21 AM | " an unknown error occurred while accessing ....central.rvt"
tim123
4 Stars: 19 Votes
Check out the mapping of the drives.  Local computers may be trying to access the central file via different mapping routes, which causes communication probelms between the files.  Ask your tech guys to check that the mapping to the server drive is the same for the different computers.
Revit 2015 error: "A fatal error has occurred..."
Thu, Oct 16, 2014 at 11:01:49 AM
Error : "Unknown error while accessing (file path & name)
Mon, Jun 22, 2015 at 7:25:09 AM
Revit Ceiling Causing "Serious Error Has Occurred" Message
Thu, Aug 29, 2013 at 3:01:57 PM
Trouble with Arch file in Structure
Wed, Sep 26, 2007 at 9:24:13 AM
Revit 2009 error message from linking
Mon, Sep 22, 2008 at 9:58:17 PM
Page generation time: 2.3538
