Forums >> Revit Building >> Technical Support >> Wall / Column Sweep
Mon, Nov 13, 2006 at 3:29:51 PM | Wall / Column Sweep
DCHNZ
Hi,  I'm having some great success with this model but have hit a snag. I have columns within the walls & I need to add a granite panel to the base of each column & along the walls. From the attached pic you will see the wall sweep does not carry through to the ends of the wall/columns. I am faced with having to create mass elements to fill in the gaps, but surely this should not be the answer. For the returns into the glazing I have edited the glazing family & placed an upstand that then ties in with the wall sweep. Short of drawing a sweep around each column is this the best way to add this detail?
 Thanks
 Danny
Edited on: Mon, Nov 13, 2006 at 3:38:27 PM
Edited on: Mon, Nov 13, 2006 at 3:55:39 PM
Mon, Nov 13, 2006 at 9:37:37 PM | Wall / Column Sweep
eldados
eldados Avatar
4.5 Stars: 8 Votes
I would not use a mass family, rather a generic solid, or you can duplicate your column family and create one with the sweep part in place (you can also make it parametric and control the height of your sweep on the column)
your image is not complete it's hard to see what you are saying...
Integrator
KarelCAD
Column sweep
Mon, Jul 2, 2007 at 10:05:20 AM
Column Capitals
Wed, Sep 18, 2019 at 8:39:07 AM
Wall sweep won't trim
Tue, Apr 25, 2017 at 2:07:17 PM
Visibility graphics of a structural column
Mon, Aug 16, 2010 at 8:21:00 AM
Custom wall shape around structural column
Sat, May 26, 2018 at 6:26:57 AM
Page generation time: 0.6226
