Forums >> Revit Building >> Technical Support >> Adding Company Logo
Mon, Nov 13, 2006 at 12:04:55 PM | Adding Company Logo
castle
castle Avatar
4 Stars: 6 Votes
I would like to add my company's logo to pictures I've been rendering in Revit, then make a JPEG.  I have been able to import our logo from AutoCAD (just as a dwg file) into the rendering under "Renderings - 3D View 1" ... but in that view you can't export the image to make a JPEG.  I tried to import the logo when in "3D View 1," but Revit won't allow it because there is no work plane.  I also tried creating a sheet with the logo, which did work, but the text looks crappy (pixelated).  If anyone has any ideas or suggestions, I would really appreciate it.  I've attached a rendering to show how I'd like it to look ...
Mon, Nov 13, 2006 at 1:38:05 PM | Adding Company Logo
framerman
4 Stars: 13 Votes
I don't suppose you have Photoshop. I made my title block business name in photoshop and did some wicked font beveling and drop shadows and such and I still get compliments about it. It gives it a 3d look that pops right out of the page.
Maybe as a last resort you could try (gasp!) Paint.
I know it's a couple of steps more. I don't know how to do it in Revit. Wish I could help you there.
Mon, Nov 13, 2006 at 2:01:17 PM | Adding Company Logo
castle
castle Avatar
4 Stars: 6 Votes
Thanks for the ideas.  I have Photoshop at home and am just starting to learn it .... but I'll play around with it as you suggested and see what happens.  I don't know if Paint will help me to do what I'm trying to do, but I'll check it out, too.  Thanks again!
Mon, Nov 13, 2006 at 4:16:35 PM | Adding Company Logo
framerman
4 Stars: 13 Votes
If you have photoshop, don't bother with paint. What you do is render your drawing, save as a jpg, then open it in photoshop. It will be your background layer, then just simply click the text button and type what you'd like. After typing, over on the right hand side (hopefully) is your layers palette. Right click where it has your text layer and select blending options. Usually all I do is use drop shadow and bevel. You can play around with the settings to get the look you're after.
Tue, Nov 14, 2006 at 10:44:03 AM | Adding Company Logo
castle
castle Avatar
4 Stars: 6 Votes
Thank you for the suggestion and instructions on how to do it .... I can't wait to try it!  Love what you did with your company's name .... it looks really cool.  I can't wait to learn Photoshop and see what else you can do to enhance what you do in Revit.  Thanks again  : -)
Creating and using sheets with company logo
Tue, Oct 6, 2015 at 3:22:53 AM
company signage on outside wall
Mon, Aug 5, 2024 at 6:14:24 PM
URGENT! blue logo revit 2012
Fri, Jun 14, 2013 at 9:45:05 AM
New Logo in Title Block - Revit Architecture 2014
Mon, Apr 6, 2015 at 10:39:49 AM
Retrieving Renderings
Tue, Mar 6, 2007 at 7:51:06 PM
Page generation time: 1.2289
