Forums >> Revit Building >> Technical Support >> Tapered Columns
Fri, Nov 10, 2006 at 1:36:53 PM | Tapered Columns
bkwasny
I'm working a project where we'd like to use a tapered wood column but I have no idea how to create one.  I haven't found any existing ones either.  Any ideas?
Thanks!
Fri, Nov 10, 2006 at 5:46:10 PM | Tapered Columns
Kellyne
I am not quiet sure what is you are looking for but you could draw a wall the length and width of your column size and then in the elevation of it (section in front of it if it is inside your building), select your wall and "edit". Then you can mody its shape, wider-narrower.
Mon, Nov 13, 2006 at 8:09:58 AM | Tapered Columns
bkwasny
I was able to do that to make the square column taper in two directions but I'd really like it to taper in all four.  Is there a way to angle walls so that they are not vertical?  Then I could work it in all four directions by editing two sides and rotating the other two.
Mon, Nov 13, 2006 at 10:37:21 AM | Tapered Columns
castle
castle Avatar
4 Stars: 6 Votes
I recently had to design an Arts & Crafts style period home with tapered columns on the front porch, so  I used the pyramid mass and edited the family to the size and shape I wanted.  I don't know if this idea will work for you or not ....  Attached is a rendering.
Mon, Nov 13, 2006 at 10:45:46 AM | Tapered Columns
bkwasny
Castle, that is perfect.  Thank you.
Mon, Nov 13, 2006 at 11:49:35 AM | Tapered Columns
castle
castle Avatar
4 Stars: 6 Votes
You're welcome, bkwasny ..... glad it helped  : -)
tapered beam
Wed, Apr 13, 2011 at 4:29:37 PM
Tapered LH Trusses
Fri, Oct 13, 2006 at 5:05:54 PM
Tapered Beams
Thu, Nov 4, 2010 at 12:53:49 PM
HB&G Columns
Thu, Jan 22, 2009 at 4:30:03 PM
Pre-Engineered Metal Building
Tue, Sep 16, 2014 at 7:42:47 AM
Page generation time: 2.0093
